RCCUMMINS89 wrote:Our ve pumps are just as reliable as a p pump....but have dynamic timing and therefore run better per hp. They just don't make massive hp.
Now the plus side to that, the engine can last a long long long time at this hp level. And the truck is still really fast due to the weight of it.
The ONLY street vehicles on the road that can run with my 6500# Ramcharger that rolls 37s is other diesels that have had thousands upon thousands of dollars worth of work done to them. Or a tuned ford....but then again they blow up before the next light anyways.
dazedandconfused wrote:Well small world. You have probably seen me running around out that way. Skilletky in up here with us and his dually runs good and really clean considering what he has done. I'd say his setup is at 400 or really close. I would upgrade your trans to a 47rh if I was you so you can gain lockup. I'll see if I can get Chris to chime in on his setup.
RCCUMMINS89 wrote:
What's done to it?
CumminsPower59 wrote:I don't know much about EMP's and all, it doesn't make a bit of difference if the battery is stone dead and you can't roll start it. If this thing is truly going to be what you want it to be, got to be a manual transmission along with having a "pull cable" shutdown.
Just my $0.02
Been reading on your thread over on the Dmax forum...interesting. Keep up the excellent work
RCCUMMINS89 wrote::shock: I never knew one would have to go to a Duramax forum in order to have a popular Dodge build thread.![]()
That's a lot of pages...........Taco, you have competition.
