Sutter1stgen wrote: Time for me to rig a pressure switch up on my ksb.
skilletky wrote:Sutter1stgen wrote: Time for me to rig a pressure switch up on my ksb.
it works awesmome!!! had mine set to come on at around 10 to 15 psi.
AHineman wrote:BC847 wrote:I'm thinking of rigging a boost activated adjustable pressure switch that will illuminate a dash mounted light when I get to . . . . say . . . 20psig.
Napa 701-1575 is the pressure switch I've got to activate my KSB at 20psi of boost. 20psi is about the max for it to consistently make and break. They make some that work for higher pressures, but the dead bands are bigger than I would like. I had mine on a Druck at work and it was changing states at 19.3-19.7 psi.
It is adjustable. Pop the rubber cap off the end and there is an adjustment screw.
http://www.napaonline.com/Catalog/CatalogItemDetail.aspx?R=BK_7011575_0361175264
You may find something that would suit you better on Napa's website, I had no luck at the store. They didn't even know they sold them until I gave them a part number.
