speedometer bounces
speedometer bounces
Postby DodgeFreak » Wed Nov 13, 2013 8:32 am
The speedometer bounces in my dads truck. The odo works fine is there a fix for it??
Re: speedometer bounces
Postby CumminsPower59 » Wed Nov 13, 2013 10:16 am
Check the VSS, the ratio adapter, drive gear, and the wiring to it all...that's where I'd start.
Postby DodgeFreak » Wed Nov 13, 2013 10:37 am
the odo works fine still if it was in the vss or adapter\wiring wouldn't the odo be messed up also?? The needle for speedo bounces bad it will hang around 30mph for a mile or so sometimes or it will bounce around 45-60 when i'm running 60 then it will drop to zero. Whens its been at or close to zero I've watched the odo and it still moves normal.
On my truck the speedo works fine but the odo sticks...lol maybe I should make one good one out of two.....
Postby DodgeFreak » Wed Nov 13, 2013 3:24 pm
I should mention also it only does it when the temps are in the 30s.
Postby BobS » Sun Nov 17, 2013 4:03 pm
The first thing I would expect was to see "rounded wear" on the square shoulders of the ratio adapter input which is causing some slippage. The lube inside the ratio adapter is probably thicker at lower temperatures and causes more resistance to turning the adapter.
The only way to check the odometer is to travel a measured mile and compare. This only works if you are still running the factory size tires.
BobS
91.5 W250 NV4500 Conversion
89 D350 Stock
BobS
Postby CumminsPower59 » Mon Nov 18, 2013 1:43 pm
BobS wrote:The first thing I would expect was to see "rounded wear" on the square shoulders of the ratio adapter input which is causing some slippage.
Seen that every time I have made repairs in that area.
BobS wrote:The only way to check the odometer is to travel a measured mile and compare. This only works if you are still running the factory size tires.
But, if one has larger than stock tires, you can use the revolutions per mile for the stock tires, and then the larger tires, divide and you have the % of difference to calculate into the equation.
Postby DodgeFreak » Wed Dec 11, 2013 11:45 am
Is the adapter to speed up or slow down the drive?? I havent looked into it much as ill be converting to 4wf
Postby CumminsPower59 » Wed Dec 11, 2013 12:41 pm
Speed up.
Postby CumminsPower59 » Wed Dec 11, 2013 12:57 pm
Another way to figure out what ratio adapter you need...kinda hokey, but if you got a smart phone, it'll work. I used it to figure out what ratio adapter I needed for my 91...
Take your smart phone and download some sort of a speedometer (they run off GPS).
Put the VSS directly on the speedometer drive on the transmission/transfercase.
Run the truck up to whatever speed, 55, 65, 70 (whatever works for you in your area) and hold steady at said speed and make a mental note of the GPS MPH and what the speedometer says.
Take the speedometer reading and multiply it by the ratios availaible here:
http://www.transmissioncenter.net/speed ... ____va.htm
(the adapters are about 1/4 down the page)
You'll want the ones that speed up...what percentage depends on the difference to get the speedometer up to the GPS speed..
Hope this helps ya
Postby ellis93 » Wed Dec 11, 2013 1:14 pm
CumminsPower59 wrote:Speed up.
Not on mine....4:11s. When mine went South,I screwed the vss directly to the drive.....that was the only time I seen my truck ever do 100mph :lol:
Postby CumminsPower59 » Wed Dec 11, 2013 1:58 pm
I'm not sure on how it all works on those 2wd's, I've only messed with 4wd's...
Postby DodgeFreak » Sun Jan 26, 2014 9:11 am
It rounded the edges on the vss. I cleaned the grease out of the gearbox and put new in. And epoxied the vss in the gear box lol
Postby CumminsPower59 » Sun Jan 26, 2014 11:22 am
Funny thing is, the speedo started bouncing on my pile, I ended up loosening up the ratio box and the VSS, I must've had them too tight or something, because I moved them around and just slightly snugged them this time and no more speedo bounce.
Postby DodgeFreak » Sun Jan 26, 2014 4:54 pm
My box was loose on the trans but im unsure why the vss rounded...i figured the box would have first...
Return to Electrical
