Postby ellis93 » Wed Feb 19, 2014 1:54 pm
Now go build :)
Postby DMan1198 » Wed Feb 19, 2014 2:02 pm
That sounds like a reasonable plan
Postby CumminsPower59 » Wed Feb 19, 2014 2:21 pm
And take lots of pictures :mrgreen:
Postby DMan1198 » Wed Feb 19, 2014 2:31 pm
I'll do my best. Hopefully this setup works and I don't have to start over again
Postby RCCUMMINS89 » Thu Feb 20, 2014 8:16 am
Both of my drivelines have been at the driveline guy for .......... 7 days now. I'm starting to get impatient. Why you ask, because I was told it would get done same day.
Postby ellis93 » Thu Feb 20, 2014 8:48 am
Yep,I'd be pissed off about it. I'd go see that moose knuckle and ask whats up,give the opportunity for him to lie to my face about it.
Postby RCCUMMINS89 » Thu Feb 20, 2014 9:10 am
Last night I called and was told that they were going to get done this morning.... if they are not done today, then I will get upset.
Postby ihredneck » Thu Feb 20, 2014 2:44 pm
Just checked in on the progress of the pillar pod, there is a prototype done and it sounds that production will be happening fairly quickly after they make sure the test fit is good.
1999 RCSB 1500 24v NV5600
2000 VW Jetta TDI
ihredneck
Postby RCCUMMINS89 » Thu Feb 20, 2014 2:49 pm
Oh, sweet....
Postby DMan1198 » Thu Feb 20, 2014 3:42 pm
That is some sweet news
Postby RCCUMMINS89 » Thu Feb 20, 2014 4:37 pm
Holy moogly boogly..... Put new trans mounts in.... Yea..... I feel like I'm sitting on the engine directly. It vibrates, SO BAD.
What I can't stand.... when I "fix something" and things get worse.
Postby DMan1198 » Thu Feb 20, 2014 5:19 pm
Sounds like you went with poly mounts? I'm sure they'd be great on an engine that ran smooth enough you could nut a peanut on the top and it would just sit there, but on our shaky things not so much
Postby RCCUMMINS89 » Thu Feb 20, 2014 5:41 pm
Factory oem replacements....
Postby dazedandconfused » Thu Feb 20, 2014 5:51 pm
I bet its touching the floor pan somewhere.
Postby RCCUMMINS89 » Thu Feb 20, 2014 5:54 pm
That's what I originally thought..... nothing anywhere. My trans and case are about a foot from the floor pan. I thought my exhaust was hitting the bellhousing or frame... and nope.
