front suspension on 2wd race truck
Postby blacksheep » Sat Mar 08, 2014 7:38 pm
i am building a 91 into a race truck. there is a good chance the front will be coming off the ground. will the fresh rebuilt front end handle the front hitting when it comes down? or is there upgrades i can do?
blacksheep
Re: front suspension on 2wd race truck
Postby dazedandconfused » Sun Mar 09, 2014 6:39 am
Is it a D250 or a D150 truck? I know the Cummins express will pull the tires a little but nothing crazy and I don't believe he has had issues.
Postby ellis93 » Sun Mar 09, 2014 8:00 am
Probably gonna have to learn to ride it out and set it down softly. That's a lot of weight to have slapping down on anything but railroad iron :)
Postby fatty » Sun Mar 09, 2014 9:37 am
Not to rain on your parade but lifting the front tires with a 1k lbs plus engine will probably take more than 6-800 hp. It's actually quite rare in diesel powered trucks, I can think of only a few people that have done/do this and they aren't even the really fast ones.
Postby RCCUMMINS89 » Sun Mar 09, 2014 9:50 am
Only ones that I know of are north of 1000hp.
Postby blacksheep » Sun Mar 09, 2014 8:32 pm
it is a d250
goal is north of 1000 hp
truck will be back halfed and 4 linked.
goal weight of the truck is 4500-5000 lbs
motor may be moved back 6-12" still trying to decide
no mattter what, the goal is to the front wheels off the ground 12" at least maybe more
blacksheep
Postby Philip » Sun Apr 20, 2014 2:41 pm
If your going to run a 4 link. Just set it up properly so it doesn't lift the front end off the ground. Set it to just skim the front tires.
Return to Competition
