cmann250 wrote:One interesting note on hydraulic fluid: someone affiliated with FirePunk Diesel is saying to stay away from the stuff because he had a valve body filter collapse on him. Valid concern?
BC847 wrote:I've been running THF with maybe two quarts of cheap ATF4 for a good while now with no issues (knock on wood). Using the typical run-of-the-mill VB mounted filter and an inline filter.
- I do run the L2L heat exchanger during the winter to heat the cold stuff though.
