RCCUMMINS89 wrote:1. dropping case pressure, thus losing timing... thus losing power.
cougar wrote:I see you have an Airdog. Are you monitoring fuel pressure perchance?
BC847 wrote:RCCUMMINS89 wrote:1. dropping case pressure, thus losing timing... thus losing power.
That's an ongoing issue with my mess.
Seen it illustrated on a dyno a while back.
fatty wrote:cougar wrote:I see you have an Airdog. Are you monitoring fuel pressure perchance?
I did for a while when I first installed it until the gauge broke. It was pushing just over 20 psi at idle IIRC.
fatty wrote:BC what have you done to remedy this.
