loosening up old rings ?
Re: loosening up old rings ?
Postby jethro » Sat Jul 05, 2014 10:20 pm
Am I correct that the hungry diesel one is the one considered to be the most reliable and best built ?
(mechanical engine driven mechanical piston fuel pump- about 250 $)
If I use that pump on the engine do I still have to have am electric pump inside the tank to work as a boost pump ?
(airplanes work like that- electric low pressure submerged pump in tank overfeeding an engine powered mechanical pump)
I think I have read that no one really trusts even the cummins pumps and their diaphragm.......
are there other piston pump possibilities in addition to the hungry diesel one ? I DEFINATELY don't want one which
has lowered reliability and leave you on the side of the road....... I am going for high reliability here.......
( I secretly know what you will say..... I just want to hear you say it so I can feel good about spending 250$ on a fuel pump )
The blow by is ALL GONE now- have run about 3-5 hours over about 10-12 short runs.
Put 1 big bottle of marvel in the oil and about 3/4 can of sea foam. Tried injecting some sea foam into the air intake-
but unlike a gas engine I could see NO reaction at the exhaust- no smoke- no change in idle - no detectable reaction.....
squirted it in with one of those machinist oilers with a pump.
oil pressure is about 50 - 60 on startup and reduces to about 38 when fully warmed up idleing. Really smooth engine.
tim
jethro
Postby RCCUMMINS89 » Sat Jul 05, 2014 11:07 pm
The lift pump is set up to run alone... no electric pumps in the tank or in line.
We use Genuine Cummins pumps.... as far as reliability, they are top notch.
