Kasper Cummins wrote:Only thing I have to add to that is if you want to skip a tooth for more time now would be a grate time.
Got Smoke? wrote:New cast cam or regrind?
opiebennett wrote:Got Smoke? wrote:New cast cam or regrind?
New. According to Jeff at Colt Cams, our cams are weaker than the 2nd gen 12 valve cams, and have much smaller (front to back) lobes, so he will not grind a performance profile into them.
93flatbed wrote:How much off set did you need to set the right cam timing. Or did you use an adjustable cam gear?
You certainly have better luck than I do when you drop a part....
oldestof11 wrote:Good!
1 word of caution: 60lbs over, according to Zach Hamilton, do have 60lbs more SEAT pressure but when it hits a certain lift, it is just as same as the stock springs.
