Check Engine Light
Check Engine Light
Postby mhuppertz » Thu Jul 31, 2014 9:41 am
New alternator, brand new yellow top battery, two different PCM's, three different ignition switches, same issue. Bouncing volt meter that sets a CEL, diag code says "low voltage condition detected".
Grounds look good, must be low voltage supply to the PCM but I can't find it!
Driving me nuts.
Ideas?
mhuppertz
Re: Check Engine Light
Postby DodgeFreak » Thu Jul 31, 2014 9:46 am
have you put an actual volt meter on the battery to make sure it was charging?
Postby mhuppertz » Thu Jul 31, 2014 10:00 am
I haven't but I drive it at night and it hasn't killed the battery, although the brightness waivers along with the needle.
mhuppertz
Postby mhuppertz » Thu Jul 31, 2014 10:05 am
I tried bypassing the PCM (with a brand new external regulator) and it did the same thing, although I did not try using a relay to bring power straight from the battery.
To me this suggests a power supply issue TO the PCM but I just can't find it.
mhuppertz
Postby PToombs » Thu Jul 31, 2014 5:23 pm
Are you checking the power to the PCM with it plugged in or unplugged? You need to check it plugged in. If you check it unplugged you will get 12 volts, but there is no load. Plugged in the PCM is drawing power and a low voltage will show right up.
Return to Electrical
