Drag link with 2.5" lift?
Postby bgilbert » Sun Nov 16, 2014 7:55 pm
Two questions. First, will a stock type drag link work with a 2.5" lift? Second, how do you determine if one is needing replaced?
I'm in the process of converting the crew to 4wd. It's time to steer the thing, I have a couple drag links laying around from 4x4 trucks I've parted. A new Moog drag link is ~$150, :roll: . If I have to buy one, I want to make sure a stock type piece will work with a SJ 2.5" front lift. The used ones I have don't look bad, but I also don't want death wobble or loose steering when I'm done. Thoughts? Recommendations?
Bill Gilbert
Re: Drag link with 2.5" lift?
Postby BILTIT » Sun Nov 16, 2014 8:36 pm
IMO, if replacing the draglink and running 2.5' lift just go with crossover for the few hundred extra bucks.
http://www.dieseltruckresource.com/dev/ ... 91427.html
Its a long read but well worth it in the end.
Derek B.
BILTIT
Postby CumminsPower59 » Mon Nov 17, 2014 4:01 am
Bill, the stock length drag link is too short for a lifted truck. I have an adjustable Skyjacker unit on mine, but if I had to do it again, I'd run a cross over setup. Another option is to use a Chevy drag kink. Jeff has something like that on his truck...
Postby bgilbert » Mon Nov 17, 2014 2:46 pm
I will not be going to a crossover setup. If I knew I'd need longer shocks, and a longer drag link with a 2.5" lift, I never would've bought these! I was only buying them because I wanted new springs for the conversion. Ugh, I'm over it! lol *Edit* $250 for the Skyjacker adjustable draglink!! Yay!
Bill Gilbert
Postby BILTIT » Mon Nov 17, 2014 3:13 pm
Custom draglink $140
http://www.partsmike.com/index.php?crn= ... how_detail
I am sure you could get them to do a double bend if required aswell.
IMO, draglink ends are the first steering component to wear. They need to be replaced frequent enough that a custom length one is a great option for that price, especially with a lift.
I tried using my stock draglink with 2" lift, no go.
Derek B.
BILTIT
Postby CumminsPower59 » Tue Nov 18, 2014 9:16 am
Funny thing is, the skyjacker adjustable drag link that is on my pile has lasted over ten years, many of them very hard years...still tight as new.
Postby Tacoclaw » Tue Nov 18, 2014 10:39 am
Can't hardly beat this deal, it just clears my crossmember with a 3" drop pitman. 2" lift on my truck.
Back the stops off and you can turn as sharp as the U-joints will allow.
http://www.chassisunlimited.com/product ... studs.html
Postby BILTIT » Tue Nov 18, 2014 11:26 am
Yup, backing off the knuckle mechanical stops so that they just stop the steering before the steering box reaches its stops greatly reduces the turning radius.
Probably one of the main benefits of crossover type steering.
Derek B.
BILTIT
Postby Fred_M1010 » Tue Dec 02, 2014 1:31 am
CumminsPower59 wrote:. Another option is to use a Chevy drag kink. Jeff has something like that on his truck...
To use a Chevy drag link or any other straight drag link, you'll probably need to bend the pitman arm to keep the DLE angle down.
Here's how I did it:
viewtopic.php?f=22&t=13462&p=112132
-91.5 W250
Fred_M1010
Postby lstzephyr » Fri Dec 19, 2014 5:00 pm
So the chassis unlimited kit fits with a 3" drop pitman on a 2" lift? I didn't know a bolt on kit existed for our trucks. That would be awesome as I don't have the tools to custom bend a crossover drag link. Tacoclaw, can you post some pictures of your crossmember clearance? Also what 3" drop pitman arm do you have?
lstzephyr
smoke screw?
Postby Tacoclaw » Fri Dec 19, 2014 5:05 pm
Minimal clearance, just barely enough to fit a finger in. (Heh) Enough for a DD but I would definitely want more for a trail truck.
I'll sniff around for my pics in a few, they're in my threadacolypse so I'm not gonna send you in there unarmed. It's also not "bolt in". You'll need to cut the draglink to length and weld the bungs in it for the ends to thread into. The rest is straight forward, I used the drop arm they have as an option on their site.
Postby lstzephyr » Fri Dec 19, 2014 5:15 pm
Thanks for the quick response. I found another thread that you responded to about it.
http://www.1stgen.org/viewtopic.php?f=2&t=15686
lstzephyr
smoke screw?
Postby u2slow » Sun Dec 21, 2014 1:16 am
I have the 2" parabolics that give a realistic 3" lift. Still using stock draglink. I'm sure its not ideal, but it works just fine for my day-to-day driving.
I'm making up a couple 'zero rate' block things and still see if I can get by with the stock one for a little while longer.
93 W250 Club 6BTA/5spd/3.54/Dana80/~3"lift/2gen leafs/3gen wheels/HX35/5x.012s
90 D250 6BT/5spd/3.54PwrLok
84 Ramcharger [Project} D250 6BT/5spd/3.07
... various other 75-05 mopar truck products
u2slow
Postby MMeier » Fri Feb 27, 2015 12:46 am
So say when you are running the stock Drag link with 2-3 " of lift , anyone tell me what happens steering wise ?
'93 W250CC, 5 speed, 3.54's, pump tweaks, NV4500 conversion, straight piped, 33's. Also, have '03 3500 QC 4WD dually, 551HP/ 1008 TQ @ MATS '07
MMeier
Postby u2slow » Fri Feb 27, 2015 2:28 am
My steering wheel was off center with my sagged stock leafs. Its still off center with the 2" parabolics... maybe the opposite way though. Can't remember. Turning circle was bad and still is bad.
u2slow
