thinking about getting injectors worked on
Postby 1992gen1_fan » Sat Dec 06, 2014 9:10 pm
I'm currently running SDX 5x12's. Theyve been good injectors but thinking about trying something different before too long.
I've got a couple options, I could send the 5x12's in to get ballenced ect. Or I could send my stock size 6x009's(?) In and get them extruded and ballenced.
I'd like them to perform same as or better that what I have now, but I want them to run clean and efficient. Absolute least idle haze possible and keep the performance. The 5x12s are fairly clean but do haze a bit sometimes, I think they're getting dirty or something.
I'd really like to get the stockers extruded but don't know if they'd compare to what I have now and be clean and effecient. :?:
What would y'all recommend.
1992gen1_fan
Re: thinking about getting injectors worked on
Postby RCCUMMINS89 » Sat Dec 06, 2014 11:39 pm
Are the 5x12 VCO or SAC? "V looking tip, or a funny ball at the end"?
Postby 1992gen1_fan » Sun Dec 07, 2014 8:13 am
I think they have the "v" tip, so VCO? Id have to double check, been a while since I looked at them.
1992gen1_fan
Postby RCCUMMINS89 » Sun Dec 07, 2014 9:46 am
Honing those 5x12 VCO will haze. But honing your stock 6 holers, won't make much more power (very similar) to your 5x12 do now.
Postby 1992gen1_fan » Sun Dec 07, 2014 3:23 pm
So your pretty sure the honed 6 hole injectors will be similar to the 5x12's? And most likely still be fairly clean?
1992gen1_fan
Postby RCCUMMINS89 » Sun Dec 07, 2014 3:59 pm
If your injectors are in good shape, they will be clean.
Fatty is running some 6x13s we honed, and he says they are still very clean... at 80lpm.
Postby DMan1198 » Sun Dec 07, 2014 4:29 pm
Where did he get 6x13's?
Postby RCCUMMINS89 » Sun Dec 07, 2014 4:55 pm
Through me.
Postby 1992gen1_fan » Sun Dec 07, 2014 5:06 pm
Ok , they should be in good shape. I think I probably put less then 10k miles after getting them rebuilt and seemed good shape when I took them out. Just VERY restrictive... Lol
I'm not even pushing the 5x12's to their potential I don't think, so if the stockers can be reliably worked to the 5x12 range than that's probably the rout I'll go. 8)
1992gen1_fan
Postby fatty » Sun Dec 07, 2014 6:40 pm
RCCUMMINS89 wrote:If your injectors are in good shape, they will be clean.
The 6x13 I got are just as clean as my stock injectors were at low/no boost. When I'm really getting on it they're plenty smoky though.
Postby DMan1198 » Mon Dec 08, 2014 10:15 am
I think I'm going to need a set of those some day (maybe spring)
Postby 1992gen1_fan » Mon Dec 08, 2014 10:57 am
Sending the stock injectors off today 8)
1992gen1_fan
Postby PToombs » Mon Dec 08, 2014 6:12 pm
Future ex-stock injectors? :lol:
Postby 1992gen1_fan » Tue Dec 09, 2014 6:15 pm
PToombs wrote:Future ex-stock injectors? :lol:
Yea exactly 8)
1992gen1_fan
Postby 1992gen1_fan » Thu Dec 11, 2014 10:04 pm
After I get the injectors back, what size copper seal washers should I use? Seems like it had some fairly thin washers but I cant remember what size had best luck with on the stock injectors.
1992gen1_fan
