1989 W350 want an intercooler
Re: 1989 W350 want an intercooler
Postby 762frmafr » Fri Dec 12, 2014 2:05 pm
So I think I have most of the mechanical gremlins worked out on the truck. I also will be replacing all 4 leaf springs and converting the rear to disc brakes in the very near future. Made a deal with a body man friend to trade out the body work. Once all that is done, it will be time for performance upgrades. I am wanting to add and intercooler and a faster spooling turbo. I am set on which intercooler to use. But which turbo. This will just be a daily driver/tow/farm vehicle. Nothing crazy. Reliability and fuel economy are important. I was looking at this one from hungry diesel. http://www.thehungrydiesel.com/Borg-War ... -60-68.htm What say you?
762frmafr
Postby RCCUMMINS89 » Fri Dec 12, 2014 2:15 pm
What fueling mods will be done? Injectors? Pump tuning? Timing? That turbo is great for the 325-400hp HEAVY hauling truck that will be INTO the turbo most of the time.
If a truck is not towing all the time and is in the stock to 350hp range, the Super B turbo is way better all around. Super B can tow extremely heavy loads, but it spools faster than the 60/68 when not using a lot of power.
375hp +......62fmw all day long.
Postby 762frmafr » Fri Dec 12, 2014 4:18 pm
RCCUMMINS89 wrote:What fueling mods will be done? Injectors? Pump tuning? Timing? That turbo is great for the 325-400hp HEAVY hauling truck that will be INTO the turbo most of the time.
As far as I know, the pump is stock right now, but I have not been inside it yet. Although it does look to be advanced. I can see paint on the engine block and it looks like the pump is turned towards the head. I do not plan to do injectors until the stockers wear out. I would like to do a fuel pin and spring...maybe add spring. I have Beans Diesel sump on order and will be doing a piston pump eventually.
762frmafr
Postby RCCUMMINS89 » Fri Dec 12, 2014 5:16 pm
Go with the Super B.
Postby 762frmafr » Fri Dec 12, 2014 5:21 pm
RCCUMMINS89 wrote:Go with the Super B.
Looking on your site, you have 2 super b's and the killer b. Can you explain to newb the difference please?
762frmafr
Postby RCCUMMINS89 » Fri Dec 12, 2014 5:58 pm
One Super B is a "kit" and the one for $1110.38 is just the turbo. The kit is pretty much worthless on a 1st gen, as BD's kit comes with 2nd gen components.
Order the turbo only, and then either order a HX40 flange downpipe or one can weld on a hx40 flange to an existing 4" d/p for $25.00. Then you'll need an HX40 exhaust clamp $25.00.
Postby 762frmafr » Fri Dec 12, 2014 6:03 pm
RCCUMMINS89 wrote:One Super B is a "kit" and the one for $1110.38 is just the turbo. The kit is pretty much worthless on a 1st gen, as BD's kit comes with 2nd gen components.
Exactly what I was looking for. Thank you. What is the killer b?
762frmafr
Postby RCCUMMINS89 » Fri Dec 12, 2014 6:14 pm
Killer B is a 63/65/14. Larger turbo, more air and more lag than stock injectors need.
Postby 762frmafr » Sat Dec 13, 2014 12:40 pm
CumminsPower59 wrote:A 2nd gen IC setup would probably be a better choice. All of the piping from a 2nd gen will work.
You'll have to cut the leg off the intake horn, as in the picture you'll see what's left when it's removed. Depending on what turbo you are going to use, hooking it up to the piping would be the only minor issue. If you used say an HX35, or even a IC H1C, it's all there. If you are going to run the stocker, you'll have to find a elbow that goes from the small outlet to the rather large IC piping.
So I found a complete second gen intercooler set up. All piping plus intake horn. What will I need to connect the second gen intake piping to my stock 89 turbo?
762frmafr
Postby CumminsPower59 » Sun Dec 14, 2014 8:35 am
Gonna have to get crafty if you are going to adapt the stock baby H1C to the intercooler. Figure out a way to get the 2" compressor outlet to the 3" intercooler piping, an make a 90 degree bend in there too. Might as well plop on a different turbo while your in there, it'll solve your current lag issue too, and you won't need to get hokey adapters to fanaggle the stock turbo to the intercooler plumbing.
Also, since it wasn't mentioned before, you'll have to modify the throttle bracket. Yes, you can do as I did in the pictures and cut the top off, but then there is just one bolt on the bottom holding the entire throttle bracket assembly on. You could weld on some tabs to re-attach it. I picked up an IC throttle bracket (91.5-93) off eBay for cheap. You'll have to do some grinding on it to go around the injection lines, 75% of part of a certain area will need to be ground down.
This isn't a 100% bolt on affair. You will have to do some sort of modification somewhere.
Postby 762frmafr » Sun Dec 14, 2014 9:15 am
CumminsPower59 wrote:Gonna have to get crafty if you are going to adapt the stock baby H1C to the intercooler. Figure out a way to get the 2" compressor outlet to the 3" intercooler piping, an make a 90 degree bend in there too. Might as well plop on a different turbo while your in there, it'll solve your current lag issue too, and you won't need to get hokey adapters to fanaggle the stock turbo to the intercooler plumbing.
So my stock turbo is 2" and the piping is 3" correct? I haven't gotten the intercooler yet. Will be picking it up this week. I will need to do a 90 right at the turbo like in your pic correct? So if I can find a 2"-3" 90 I would be golden right?
762frmafr
Postby 762frmafr » Sun Dec 14, 2014 10:26 am
762frmafr
Postby CumminsPower59 » Sun Dec 14, 2014 11:40 am
762frmafr wrote:Something like this maybe?
http://www.siliconeintakes.com/bending- ... p-953.html
Possibly. I'd double check the sizing just to be sure. I've been known to be wrong before ;)
Postby 762frmafr » Sun Dec 14, 2014 12:18 pm
Will do. Thanks for the info. Just to clarify though, the only 90 and reducer I will need is right at the turbo hot side correct?
762frmafr
Postby CumminsPower59 » Mon Dec 15, 2014 6:40 am
Should be.
