Tacoclaw wrote:These oughta be strong enough for you bunch of fatties.
http://www.chassisunlimited.com/product ... r-kit.html
DMan1198 wrote:So my bosses service truck (f550) has been making a really annoying squeak/rattle for the last little while that was coming from the running board area. Turns out the sheet metal right above the top mounting holes had ripped from the amount of weight they were subjected to (a lot of mud mostly) so I spent about an hour today figuring out what the squeak was, and fixing it. So heads up Caleb that might happen to your heap
DMan1198 wrote:Oh that's right
A Cummins would fix that issue
PToombs wrote:Tacoclaw wrote:These oughta be strong enough for you bunch of fatties.
Those are nice, but I'm not sure if the 12" tube is long enough to go from the frame on a FRT. Plus, I want something to keep the crap off the rocker panels.
cmann250 wrote:I'm a bit afraid to check if I have PMRs. Sad thing is for those of us driven by money, a forged rod long block for a 7.3L is cheaper than a Cummins. Swap accessories and go to town. I looked and to get everything perfect, it's $4000 plus the engine to swap a 12v in my truck. Sadly I can't justify that in something that isn't a toy.
