2015 BS and Chat Thread!
Re: 2015 BS and Chat Thread!
Postby ellis93 » Sat Jan 03, 2015 3:39 pm
oldestof11 wrote:Why the lift? You can tuck 37's with a 4" lift. You aren't gaining ground clearance.
Cool points with the ricer crowd or over compensating for a shortage ...you pick :lol:
Postby Tacoclaw » Sat Jan 03, 2015 7:18 pm
Shit, I've got 37" with springs that are bowed over backwards.
Postby DMan1198 » Sat Jan 03, 2015 10:32 pm
There's also a 4th gen out there with 37's and no lift. He's running +18 offset 18's, and apparently doesn't rub at all (I don't think he's trimmed anything either
Postby DMan1198 » Sat Jan 03, 2015 10:38 pm
On another note I did the 6 hour trip to Calgary today for school on Monday. Roads were semi decent until the last 45 minutes to an hour when I ran into snow. Nearly got close to losing it once in 2wd, so switched to 4, and listened to the one binding u-joint complain
Postby RCCUMMINS89 » Sat Jan 03, 2015 10:52 pm
I'm out, you guys suck
Postby CumminsPower59 » Sat Jan 03, 2015 11:11 pm
No, you suck! :P :mrgreen:
Postby DMan1198 » Sat Jan 03, 2015 11:44 pm
I Did say 6" didn't I? I didn't just think about it then forget like what seems to happen so often
Postby dazedandconfused » Sun Jan 04, 2015 6:35 am
Personally I'd level the 06 and lower the RC some so you stop having drive line issues with it.
Postby ellis93 » Sun Jan 04, 2015 7:34 am
RCCUMMINS89 wrote:I'm out, you guys suck
Geez,tender much? :)
Postby Tacoclaw » Sun Jan 04, 2015 8:44 am
Brah, if it's not completely unusable, how's anybody going to take it seriously as a company vehicle? ;)
If you want to make it a spectacle for THD, then go big. 8", 37x15", ridiculous offset, go for it.
You shoulda already known nobody here would be into that stuff. Well, Dmann I guess, but I can't think of a single ridiculous 1stgen I've seen on a forum. There's a bunch of them on FB though, it seems a new one turns up every day.
Postby fatty » Sun Jan 04, 2015 9:49 am
Dman is a 4th genner though so he doesn't count. :D
Postby DMan1198 » Sun Jan 04, 2015 11:13 am
My 1st gen is lifted. I just like a taller truck is all
Postby RCCUMMINS89 » Sun Jan 04, 2015 1:30 pm
An 8" lift on a common rail doesn't make it useless.....They are not like a 1st gen, where if you lift them 4" you can't use 4wd without a vibration.
I'll end up with a 6".... I want an 8, but I refuse to drive around on 40" tires. And 37s look small on an 8... and look perfect on a 6.
IMO jamming way the hell too big of tires on a truck looks just as dumb as way too small. A leveling kit with 37s looks completely homo to me.
Postby RCCUMMINS89 » Sun Jan 04, 2015 1:32 pm
And as far as the Ramcharger....... it ONLY has a 3" suspension lift. The rest was body, which was a necessity to use the frame.
I also will not drop it below a 37" tire because it has 4.10 gears. I tested it with 35s and it sucked for how I use it.
And my driveline issues really are not that big, most don't notice it... but there are other ways to fix those issues.
Postby oldestof11 » Sun Jan 04, 2015 3:32 pm
Just giving you chit Eric.
I woke with a sore throat and headache today. I have been having many brain farts today. Most notably is me making breakfast. I got down a bowl to whip up some scrambled eggs. I crack the egg open and proceed to open the egg over the sink. Yep. Dropped the good stuff into the disposal.
And it snowed 2.5" last night. :mrgreen: I love this weather! I took the Subbie out to do some shopping and was doing donuts in the parking lot.
