So far I've replaced the plugs, wires, coolant sensor, and map sensor. None of these have changed anything, it still cranks and smells like gas but seems to have no spark. The check engine light is on while cranking but that may be normal, I'm not at all familiar with there rigs.
Before I replaced anything, I sprayed starting fluid on the filter-no result. Sprayed a bunch directly into the intake manifold and had this result. https://www.youtube.com/watch?v=g3wriQn7-SQ A little scary but burned itself out in about five seconds. It must have at least an intermittent spark then?
I wish every engine was a VE 12 valve, it would make life so much simpler.
