adjusting upper control arms
Postby boomerbabe » Wed May 27, 2015 10:09 pm
Hi guys. I have to replace my upper control arms - bottoms look good. The upper ball joint hole are worn and I don't want to weld in my new moogs. When I tear these off - my aligment will be off and I am wondering if there is an easy way to do a simple alignment after I get them in. Are there any posts on this subject? Thanks! John
boomerbabe
Re: adjusting upper control arms
Postby oldestof11 » Thu May 28, 2015 2:36 pm
I took pics of the camber bolts and matched them up as best as I could when I installed new ones. Toe is spot on and camber looks good.
Postby boomerbabe » Fri May 29, 2015 12:20 am
Thank you so much for that...I will do the same thing! Have a great day. John
boomerbabe
Users browsing this forum: No registered users and 69 guests
