2015 BS and Chat Thread!
Re: 2015 BS and Chat Thread!
Postby RumbleFish » Fri Nov 20, 2015 3:11 pm
Haha its pretty ridiculous. Would you believe the idle is the only reason i put it together?? I had nearly everything "in stock" and did it just because it sounds tough and confuses the uneducated.
Postby DMan1198 » Fri Nov 20, 2015 8:08 pm
That is probably the meanest sounding neon I've ever heard.
On another note since I have no life I took the 1.1 t4 housing I'm using on my primary and smoothed it out so hopefully the high temp paint will stick better. Here's the result after about 5 hours worth of work.
Postby matthewh » Fri Nov 20, 2015 8:15 pm
Picked this new toy up last weekend. Its a non-winch soft top model, no cargo cover or bows, but man, it runs good. Other than some clogged fuel filters on the journey home, smooth recovery. Driven a few deuces, but this ones fast, easily do 60, holds speed going up a hill, I'd have no problem pulling into busy traffic with it. Just plain fun to drive
matthewh
Postby RumbleFish » Fri Nov 20, 2015 8:38 pm
Omfg im soooo jealous
Postby DMan1198 » Fri Nov 20, 2015 8:49 pm
Me too. That thing looks killer. I've driven one deuce and a half, and the first time I did it had no brakes which was scary since the yard was sloped. I did end up getting them to work good after I finally gravity bled the brakes
Postby matthewh » Fri Nov 20, 2015 9:09 pm
That's one of the downsides, single circuit brake system. Been keeping an eye out for a retro kit from a later air force deuce, some had dual circuit systems. I'd love to sling a set of 5-ton air brake axles under it, maybe down the road. Just gonna drive it for now
matthewh
Postby DMan1198 » Fri Nov 20, 2015 10:08 pm
Yeah this one had an air assisted hydraulic setup. Worked good after a bunch of work.
Postby matthewh » Fri Nov 20, 2015 10:48 pm
This ones the same way air over hydraulic.
matthewh
Postby DMan1198 » Wed Nov 25, 2015 6:57 am
Did anyone else have a problem where they couldn't get on here over the last few days?
Postby matthewh » Wed Nov 25, 2015 6:59 am
Yeah, we all did, server was down
matthewh
Postby DMan1198 » Wed Nov 25, 2015 7:37 am
Makes sense. Just wanted to make sure I wasn the only one
Postby fatty » Wed Nov 25, 2015 7:45 am
That was scary. Dmann 1stgen.org has a fb page where you can check if something isn't working.
Postby DMan1198 » Wed Nov 25, 2015 7:49 am
Being in camp right now with no wifi I'm avoiding all social media. Just going on forums for the time being, but thanks for the info
Postby PToombs » Wed Nov 25, 2015 6:30 pm
I told swank there were about 20 junkies going thru withdrawal, he just laughed at me. :(
I couldn't find the fb page for a while, had to dig for it. I "liked" it a while back, but it doesn't show up in my feeds.
Postby DMan1198 » Wed Nov 25, 2015 8:36 pm
I just about did. Had to deal with just those cf people, and a bit of compd
