Straight H2O
Straight H2O
Postby spencerdiesel » Tue Dec 01, 2015 7:13 pm
I know straight water injection drops temps, but because of the lower temps, will any extra power be freed up? I've heard several people say no, and a few say maybe. Kinda like taking an HX35 to 400 hp then swappin on a bigger/better charger?
Also, what are some more budget friendly water/meth kits for our trucks. I know I get what I pay for, but still want to know the tried & true setups.
Re: Straight H2O
Postby DMan1198 » Tue Dec 01, 2015 7:18 pm
In theory power gains from straight water would be negligible. While cooler charge temps improve air density I'm not aware of it being significant enough for a noticeable power increase. Now when you add methanol that's when performance increases can be noticed. Though that is due to extra combustible material being added
Re: Straight H2O
Postby spencerdiesel » Tue Dec 01, 2015 7:50 pm
Thank you. Anyone have numbers for mpg & how much water or WM is used under high fuel/boost?
Re: Straight H2O
Postby JQmile » Thu Dec 03, 2015 2:57 am
I run two 625ml nozzles wide open when the big boost hits. I made 433rwhp with an HX35 on a 2nd Gen, so I would say an HX should be capable.
JQmile
