1989 D250 won't crank with key?
Postby jmos4 » Sat Feb 06, 2016 3:22 pm
Hi,
I just changed my battery cables and battery, the engine won't start with the key and the blinkers light up on the dash. The truck has been sitting for a bit.
I can jump the solenoid and it starts and runs, but the gages are not working as well as the rear tail lights
Also is there a source for the grid heater connector, the 4 gage single connection? I had to cut it back due to it badly corrode.
Regards,
Jim
1992 Dodge 250 4 x 4
currently 360 TBI
NV4500, NP241
Dana 60's 4.10 gears
soon to be Cummins powered
1989 D250
Cummins NV4500 (Donor)
jmos4
Re: 1989 D250 won't crank with key?
Postby Philip » Sat Feb 06, 2016 3:53 pm
NAPA should have those connection in stock. Solder them on.
Check your fuse links and see if any are bad.
Postby jmos4 » Sat Feb 06, 2016 3:58 pm
Hi,
NAPA is who made the cables and they couldn't find a replacement for that one do you have a part number?
Where are the fuseable links, l check the fuse panel and have power at all of the fuses, could it be anything to do with the wires at the positive cable?
I looked around but didn't see anything burned up, but wasn't sure where to look.
Regards,
Jim
currently 360 TBI
NV4500, NP241
1989 D250
jmos4
Postby PToombs » Sat Feb 06, 2016 5:36 pm
Sounds like a bad ground for the tail lights. When the blinkers light up, it usually is because of a bad ground to one or more of the parking lights
Postby Philip » Sat Feb 06, 2016 5:50 pm
The fuse links are by the driver side hood hinge. It is a single wire that feeds into a Y block that has 4 or 5 wires coming out of it. The smaller wires are the fuse links.
Here is a terminal that will work. The number is a Doorman number. NAPA can cross it.
http://www.oreillyauto.com/site/c/detai ... &ppt=C0335
Postby jmos4 » Sat Feb 06, 2016 7:14 pm
Hi,
I know about putting eyeloops on the wires I was speaking about the 4 gage wire that has a black quick connect connector as the wire was corroded and the corression went through the to the connector, hence wanting to know what the connectors part number was so I could make a new short cable
Regards,
Jim
currently 360 TBI
NV4500, NP241
1989 D250
jmos4
Postby Philip » Sat Feb 06, 2016 9:22 pm
That connector I have never seen in the after market. That wire is your main feed from the alt. Used channels is about your only option there.
Return to Electrical
