I need fuel filter specs
Postby spencerdiesel » Fri Feb 19, 2016 7:19 am
Looking at filters and seperators for my dual filter head, it's a 7/8-14 size.
I'm looking for a 20-25 micron FS, and 8-12 micron FF.
I swear Fleetguard abhors givin details. Thanks guys
Re: I need fuel filter specs
Postby PToombs » Fri Feb 19, 2016 5:36 pm
Yeah, I agree on that! Several times I went to their site looking for specs and found less than nothing.
Postby Gots_a_sol » Sat Feb 20, 2016 9:24 am
Wix has the specs for their filters posted.
You can search by filter type, then by the specs you want http://www.wixfilters.com/Lookup/FilterBySize.aspx
Looks like a limited choice in the 7/8-14 category though...
-Joe
Gots_a_sol
Postby spencerdiesel » Sat Feb 20, 2016 7:56 pm
Thanks gentlemen
Postby DMan1198 » Sun Feb 21, 2016 10:22 pm
Why such a big micron fuel filter? Tolerances on the pump internals are usually 1-3 microns.
The ones I have on The Roo Hunter are ff5320 2 micron fuel filter, and fs1212 fuel separator
Postby DMan1198 » Sun Feb 21, 2016 10:25 pm
Both are fleetguard
Postby PToombs » Mon Feb 22, 2016 5:31 pm
I was thinking around 10 micron for the primary and 2-3 for the secondary. Now I have a 10 micron for primary and secondary and would like to change to a finer micron.
Postby spencerdiesel » Tue Feb 23, 2016 7:40 am
Did y'all notice any drop in inlet pressure with the finer micron? Dman what lift pump is on the roo hunter?
Postby DMan1198 » Wed Feb 24, 2016 1:27 am
I have a raptor 100, so mines electric. I have a fuel pressure sender mounted after my filters, but I haven't gotten around to hooking it up yet
Postby spencerdiesel » Wed Feb 24, 2016 10:00 am
Ok. I've got a 15 psi spring I can put in the LP if fuel pressure gets low from oil/restriction
Postby spencerdiesel » Wed Feb 24, 2016 1:28 pm
Is the 212013s dual filter head (same on industrial 6b's) a straight bolt on?
Postby PToombs » Wed Feb 24, 2016 3:26 pm
Yes, sort of. The adapter uses a longer stud than a single filter set up. You pull the filter stud, put on the dual filter adapter, then screw in the longer stud to hold it.
Postby spencerdiesel » Wed Feb 24, 2016 4:17 pm
Thanks Pete. Is there a Cummins part number for the stud? The filter head didn't come with one
Postby PToombs » Thu Feb 25, 2016 5:43 pm
Case part numbers, they come up all over the web, J925955 for the stud, and J903293 for the holding nut. There should be 2 O-rings to seal it between the adapter and the head.
Look here, http://partstore.casece.com/us/parts-se ... 13ar852458
Postby spencerdiesel » Thu Feb 25, 2016 7:36 pm
You're right, stud and nut are all over google. Might not be a difference, but bringing up the stud also shows a (different looking) dual filter head. Is there any difference?
