New engine is back.
Re: New engine is back.
Postby spencerdiesel » Sat Apr 02, 2016 9:30 pm
Updates?
Postby DMan1198 » Sat Apr 02, 2016 9:47 pm
He's got 6x16's in now, and it really likes timing
Postby RCCUMMINS89 » Sat Apr 02, 2016 10:11 pm
I'm not talking to it right now. It has a tick.
Postby RCCUMMINS89 » Sun Apr 03, 2016 9:37 am
A more in depth update......... me personally, am about a second away from sending my old 92 block off to far away, country known machine shops and then myself building it.
To this 89 block........... my engine builder has built hundreds of engines in his life, that work just fine, many are competition engines. We have had the entire engine spec'd out by 2 machine shops. This was after the first time when the wrist pins were having issues. No one could find anything at the time....... so we decided to replace the bushings and do it again.
This noise is different. My point in all of this is.......if something is wrong again, 2 machine shops and 1 builder have no idea why.
But i will say this "tick" turns into a knock when the engine is hot enough....something is definitely wrong somewhere. But it doesn't have that rotating assembly rpm type thing. Where when you load/unload it it gets "loose", it doesn't have that. It is just like something is hitting something. And it is not a valve.
However........ I was told by Hamilton that some early trucks, the rod caps can hit the cam lobes. Supposedly (at least some) early "industrial engines" had wider rod caps on them. Ryan said some flat out smack, other may miss by a thousands or two.
Maybe that is it......... if it is barely clearing, and when it warms up is smacking it.... hitting the rod cap would also tq the rod sidways, which could also grab the wrist pin if hard enough. That's my only lead to a potential cause. It may not be it..........but ?
Postby DMan1198 » Sun Apr 03, 2016 10:41 am
Ouch. I've heard of that happening with 12v rods in 6.7's actually (billet rods too maybe. I can't remember). An engine builder friend of mine said turning the rods around fixed the issue.
Postby jdiesel_us » Tue Apr 05, 2016 4:22 pm
Wow that is a scary thought having the rod caps hit the cam!
jdiesel_us
Postby dazedandconfused » Tue Apr 05, 2016 4:49 pm
It would be easy to see if they were hitting once you pulled the engine. Flip it over and pull the pan then rotate engine.
Postby RCCUMMINS89 » Fri Apr 08, 2016 3:28 pm
And that might not be it.......... I've had quite a few guys listen to it and everyone of us are a "I honestly don't know if that is a bad noise or not" attitude.
But nothing has blown up yet. Maybe it is some weird combustion noise??????
All I know........ these 6x16 with large feed bodies and pintle mods are still cleaner (minus idle) than any injector was in my old 12 valve. This thing flat eats the fuel I throw at it.
Postby ellis93 » Fri Apr 08, 2016 4:38 pm
Remember......mine makes weird noises too. Only time it doesn't is wide open....above 2k rpm. It honestly has gotten better with the extra timing.
Postby RCCUMMINS89 » Fri Apr 08, 2016 5:05 pm
You can hear mine tick from across a parking lot. When it is hot it has a knock. They both come and go........ it's weird.
I wish I had electronic timing control. This thing needs a lot more idle timing than cruise timing for optimum "tuning" and then LOTS of wot timing for best wot timing............ I need a damn cp3 on it.
I think I am too much of a perfectionist in tuning......no matter what something is always not perfect. It bugs the hell out of me. And one can only do so much with what ya've got. I've gotten so I can get into any vehicle and all I notice is "timing is wrong here, afc is too advanced here, not enough here, turbo needs to spool quicker, gate housing is too restrictive". It's a freaking curse.
Postby PToombs » Fri Apr 08, 2016 5:10 pm
Wanna drive my truck for a few weeks? :lol:
Postby ellis93 » Fri Apr 08, 2016 6:42 pm
RCCUMMINS89 wrote:You can hear mine tick from across a parking lot. When it is hot it has a knock. They both come and go........ it's weird.
I know.....a little something about that. I've just got no time to investigate. I've had those freakin tips for what seems like an eternity.....in their freakin box still.
Postby spencerdiesel » Mon Apr 11, 2016 6:34 am
Does a VE 24v sound any different than a VP?
