DodgeFreak wrote:would the knuckles and hubs from the 60 fit? worst case could you split the stub shafts at the ujoints and run the outer stubs on the 61 inner axles? Just wondering
Dodge Dually Nut wrote:So if I get this right if I give up on the 3:07 I could take the front axle from my 92 250 and change it to the wider stance of the 1 ton?
Dodge Dually Nut wrote: I've not looked that close to how its all put together yet so excuse my temporary ignorance.
Dodge Dually Nut wrote:I'm trying to find a D61 front end no luck yet. I should be able to look at the classified now on this sight.
