93oneton 2.0
Now for the good stuff!
Postby 93oneton » Tue Oct 04, 2016 9:44 am
The cab and chassi are still at my place. Which is fine cause i have been tinkering with the motor.
Here is it how it sits now
The fun stuff!
Have done some test and tuning around the back roads by my place. 60lbs of boost is what shell pull right now. Still have some playin ro do with it, but im super happy!
Did you get your fix farmboy! :mrgreen:
Shit happens
93oneton
Re: 93oneton 2.0
Postby Farmboy » Tue Oct 04, 2016 11:19 am
ah yeah.. that'l do. lol
It's looking really good!
Farmboy
Re: 93oneton 2.0
Postby 93oneton » Tue Oct 04, 2016 1:32 pm
Farmboy wrote:ah yeah.. that'l do. lol
Hahahaha, thought it would. Thanks, im happy with it.
Shit happens
93oneton
Re: 93oneton 2.0
Postby 93oneton » Tue Oct 04, 2016 6:58 pm
Got my ssmoke rack back from powder coating. Looks good!
Shit happens
93oneton
Re: 93oneton 2.0
Postby 93oneton » Sun Oct 09, 2016 9:02 pm
Since doin the new updates to the truck i hqve noticed a small drip of oil comin from the dip stick every so often. Never noticed it before the tear down. So i figured it might need a vent in the valve cover. I wasnt able to feel any preasure bein built up in the dip stick tube or the oil fill tube. But figured it couldnt hurt.
So i picked up a k&n crank case filter with a 1/2 nipple and a pcv grommet for a mid 90s chevy. I measured out the location and installed the filter. I built a baffle out of some thin aluminum and mounted it to tue bottom of the valve cover. I drilled and tapped the 2 casting posts on either side of the area the vent is in. I used 2 6-32 screw with loc tite on them. Then i put a small amount of jb weld around the heads of the screws. Dont need them backing out! I ran the motor till it warmed up then made a few good pulls up and down my road. No oil on the top of the baffle or on the filter stem. Also no oil out the dip stick!
Next ill be up sizing my fuel line>:)
Shit happens
93oneton
Re: 93oneton 2.0
Postby 93oneton » Tue Oct 11, 2016 9:48 am
Got some Dyno time for the truck on Friday. Hopefully this evening I can get my fuel lines replaced with a larger size and get my tach hooked back up. Can't wait to see what it makes for power!
Shit happens
93oneton
Re: 93oneton 2.0
Postby DMan1198 » Fri Oct 14, 2016 3:52 pm
Nice man. I used 3/4" stuff when I added extra crankcase ventilation on my 4th gen, and that's done nicely for curing the overpressure issue. I've been debating adding a second 3/4" line to my tappet cover for a nice clean look.
Re: 93oneton 2.0
Postby 93oneton » Tue Oct 18, 2016 6:51 pm
So i took my naked crew cab down tonrun on a dyno before heading to the body shop last Friday. What a disappointment:frown2: i had a number in my head and it was close but not close enough. She put down 361.4 hp. I dont have a torque reading cause the diesel performance shop who owns the dyno cant read torque specs on a diesel. Kinda wierd i think. You can see in the video it cleans up the fuel at top end really well. The pump is pretty maxed out. So i ordered a set of 5x.016 nozzles to replace my 5x.014s.
https://youtu.be/Oo2TvMQToKk
I also figured out when i dropped it off at the body shop that it was in 4wd! The hubs where unlocked so it was spinnin the tcase and front axle. Im sure that was robbim alittle hp! I guess when its done ill have to fimd a northwest dyno day and go run it
Shit happens
93oneton
Re: 93oneton 2.0
Postby DMan1198 » Wed Oct 19, 2016 9:36 am
Looks like if you could clean up more of the low end smoke it'd make a few more ponies as well.
Re: 93oneton 2.0
Postby dazedandconfused » Wed Oct 19, 2016 9:41 am
What is your setup right now.
Re: 93oneton 2.0
Postby 93oneton » Wed Oct 19, 2016 11:35 am
I've got a Borg Warner k-27 and a Borg Warner sxe 369 with the 1.00 A/R turbine housing. I'm running 5×.014 injectors (i just ordered a set of 5x.016 nozzles). Hungry diesel fuel pin, lift pump with 3/8i.d. fuel line feeding it, m&h timing spacer and a 366 gov spring. Im sure there is something im missing lol.
Yeah i can stand to loose alittle off the line fueling for sure. The truck is at the body shop right so when it gets back and it's all together I'll do some more fine-tuning on it
Shit happens
93oneton
Re: 93oneton 2.0
Postby 93oneton » Wed Oct 19, 2016 11:36 am
It was pulling right at 60 pounds of boost and 1150 on the egTs
Shit happens
93oneton
Re: 93oneton 2.0
Postby 93oneton » Thu Oct 20, 2016 5:58 pm
So here is a dyno run and a description of my compound kit from pdd. Its on a p pump truck but the same setup
https://youtu.be/LpG6drdBh8A
Shit happens
93oneton
Re: 93oneton 2.0
Postby 93oneton » Tue Nov 01, 2016 11:41 am
Small progress updates comma The Body Shop is test fitting the doors and got the hood clearanced for my intake horn. It's all steps in the right direction
Shit happens
93oneton
Re: 93oneton 2.0
Postby DMan1198 » Tue Nov 01, 2016 1:51 pm
Very nice. The hood clearencing is a bit of a bummer. That was one thing I spent a bunch of time on building my compounds was making sure my hood closed properly.
