'91 D-250 Resto Thread
Re: '91 D-250 Resto Thread
Postby BigPapa » Tue Mar 21, 2017 6:26 pm
Ace Hardware?
Scott
BigPapa
Postby PToombs » Wed Mar 22, 2017 5:37 pm
Maybe Home Depot or Lowes too!
Postby meby » Thu Mar 23, 2017 8:49 am
Found some through Fastenal that should be the right ones. Should come in the mail today.
-1991 D-250 bone stock
-1997 Civic Hatchback
-Case 530 CK
-Speedex Walking Tractor.
-BCS Walking Tractor
www.ebyfarmsllc.com
meby
Postby meby » Thu Mar 23, 2017 7:12 pm
Serviced the trans tonight. Fluid and filter. Adjusted the bands and increased the line pressure a little. Really crisped up popping it in gear. Can't wait to see how it shifts.
Also put the wiper linkage back together. I really should have done that before I installed the cab. Would've been a lot easier.
-Case 530 CK
www.ebyfarmsllc.com
meby
Postby meby » Mon Mar 27, 2017 7:29 pm
Is it possible to reverse the wiper linkage? The driver side arm hits the bottom in park and pushes out over the outer upper edge when wiping. the passenger wiper barely overlaps​ the driver wiper path.
-Case 530 CK
www.ebyfarmsllc.com
meby
Postby DodgeFreak » Tue Mar 28, 2017 9:26 pm
not sure but it sounds like it lol.
Postby meby » Sat Apr 01, 2017 4:45 pm
New shoes.
-Case 530 CK
www.ebyfarmsllc.com
meby
Postby meby » Sat Apr 01, 2017 4:48 pm
New sound system. Added rear speakers.
-Case 530 CK
www.ebyfarmsllc.com
meby
Postby meby » Sat Apr 01, 2017 4:52 pm
I think it was time to change the filter. Almost done servicing it.
-Case 530 CK
www.ebyfarmsllc.com
meby
Postby meby » Wed Apr 05, 2017 3:15 pm
I borrowed dad's decibel meter today. Because of the cabs delapidated state, I couldn't get a before reading. At 55 mph, dry roads and 30 mph winds it reads 70 decibels. I still have the passenger side door panel off and I may do a little more to the back of the cab and above the headliner for sound control. Interestingly, it was noisier higher in the cab than at seat height. Also noisier by the door glass, but I expected that. Just comparison sake dad checked his 05' this morning same speed and conditions his is about 68.5 decibels. Both trucks are straight piped. I'm running a non overdrive non lockup auto, so I reckon if I ever convert to an overdrive trans it should be just as quiet as the 05'. Needless to say, I'm very pleased.
On a separate note. I changed the rear differential oil tonight about a half hour after I drove it and the differential was mildly warm to the touch. Roughly 70 degrees.
Is that normal?
Edit: btw 55 decibels at idle in mine.
-Case 530 CK
www.ebyfarmsllc.com
meby
Postby PToombs » Wed Apr 05, 2017 5:20 pm
Sounds normal to me. :grin:
Postby Philip » Thu Apr 06, 2017 6:15 am
Mat the sound level would drop if you threw a OD trans into the truck. At 60 MPH your turning about 2k RPM with your current trans. With a Auto OD at 60 MPH the engine would be turning around 1650 RPM. Less RPM is always quitter with our engines. :mrgreen:
Postby meby » Thu Apr 06, 2017 4:31 pm
Philip wrote:Mat the sound level would drop if you threw a OD trans into the truck. At 60 MPH your turning about 2k RPM with your current trans. With a Auto OD at 60 MPH the engine would be turning around 1650 RPM. Less RPM is always quitter with our engines. :mrgreen:
I have no doubts about that! My plan is to start watching for a manual trans and do a swap down the road.
-Case 530 CK
www.ebyfarmsllc.com
meby
Postby meby » Mon Apr 17, 2017 5:51 pm
Does anyone know where I can get some clips for my interior door panel?
-Case 530 CK
www.ebyfarmsllc.com
meby
Postby ellis93 » Mon Apr 17, 2017 7:03 pm
meby wrote:Does anyone know where I can get some clips for my interior door panel?
O'Reilly has them. Ask them for their disco fastener book.
