Hey guys I am having some problems with my overdrive and headlights and dash lights flickering like crazy.
The overdrive stopped working recently. I installed a potentiometer in place of the TPS, no luck.
I was able to jump it and get to work with a switch, less than ideal.
I was going to install a pressure switch but the 4x4 shifting mechanism seems to be in the way of the pressure port needed. So I am back to square 1.
I adjusted the cps and it seems to have good ground, 5v refrence and proper signal voltage depending on where the air gap is.
I hotwired the power side and let the computer control the ground. I tapped into pin 55 ran a wire from pin 55 to the cab. I used this wire to force a ground for the od solenoid, that didn't work. Odly enough after I removed the pin55 jumper and wire it started working. I had to adjust the TPS(now a POT) and kickdown cable to get it to work properly but it shifted in and out of OD for a good 3 days.
Sweet, problem solved.
No such luck, this morning on my way to work, again I had no overdrive. The headlights and dashlights have always flickered and the gauges bounce like crazy but this morning was much worse than before.
Im thinking my PCM has had enough and needs replaced.
Oh and the speedo and AC work.
