Turbos he351 and s363sxe choices
Postby Justgosurfin » Wed Dec 04, 2019 9:41 am
So I decided to go the he351 route for now bc the PO gave me one when I bought the van (1990 12v swapped E350)
Over the next year I think I’ll start doing valve springs and studs to get ready for a s362sxe, but need to make sure it will fit with my flipped manifold and lack of space.
Does anyone have a pic of their 362 with wastegate? Just trying to get an idea of how it’s oriented.
Also any comments on spool time for the borg warner? I drive around town a lot and want quick spool and little to no smoke.
Thanks.
1995 Ford E350
‘90 12v
Dana60-NV4500- NV271-10.5
2nd gen IC
THD Pin and HVLP
3200 spring
Timing spacer
370 injectors
Justgosurfin
Re: Turbos he351 and s363sxe choices
Postby BC847 » Wed Dec 04, 2019 5:04 pm
Keep in mind this install is with the stock location manifold that's been flipped . . . .
Postby Justgosurfin » Fri Dec 13, 2019 3:00 pm
Thanks that’s exactly what I needed to see. My manifold is flipped.
How much does the wastegate actuator stick out past the compressor housing?
1995 Ford E350
‘90 12v
2nd gen IC
THD Pin and HVLP
3200 spring
Timing spacer
370 injectors
Justgosurfin
Postby Justgosurfin » Fri Dec 13, 2019 3:01 pm
BC847 wrote:Keep in mind this install is with the stock location manifold that's been flipped . . . .
Also, what do you use that stand for?
1995 Ford E350
‘90 12v
2nd gen IC
THD Pin and HVLP
3200 spring
Timing spacer
370 injectors
Justgosurfin
Postby BC847 » Mon Dec 16, 2019 3:31 pm
Justgosurfin wrote:Thanks that’s exactly what I needed to see. My manifold is flipped.
2~3ish inches give or take.
Postby BC847 » Mon Dec 16, 2019 3:36 pm
Justgosurfin wrote:Also, what do you use that stand for?
I built it to generally mimic the basic long-block for the purpose of fitting mess to it.
