Camplate R&D
Postby ford69557ci » Thu Feb 21, 2008 4:52 pm
It should be faster but Im tryin to put that power down with ladder bars and a 29x10.5 tire or drag radials. Don that pass had a 167mph trap and that was the fastest its ever been due to tuning and other probs it stays in the low 8 range for now. I use an old manual bar type torque wrench and i just ran it down 5lbs at a time with new bolts from cummins and a warmed up engine. i did bust a few stock bolts at 145ftlb.
ford69557ci
Postby KTA » Thu Feb 21, 2008 5:18 pm
Curious did you torque them dry or use the factory recommended motor oil coating? Also were the threads chased in the block before assembly? I just can't imagine the bolts holding to that kind of torque, I never could even get close without them stretching and stretching and stretching till they break.
Postby ford69557ci » Thu Feb 21, 2008 7:18 pm
yes the threads were chases and cleaned out with brake clean and i didnt use motor oil i used some stuff called Tap Magic. I did break some of the original head bolts but the new ones took it fine maybe i just got really lucky lol. that has been happenin alot with this truck till the bottom end let go.
ford69557ci
Postby KTA » Thu Feb 21, 2008 7:27 pm
Tap Magic is a cutting oil, not a thread lube, that could explain the odd torques. I will have to try some on a bolt sometime to see how much friction diffrence there is. I know if you use neverseeze on a head bolt they wont even come up to rated torque. I know because a guy junked a dt466 block trying that onetime, pulled all the threads out. OOPS!!! lol I got to sell an engine block for that one.
Postby ford69557ci » Thu Feb 21, 2008 7:41 pm
i bet that wasnt cheap hahaha. i use that tap magic on alot of stuff its slicker than baby snot. i rubbed motor oil on my fingers then tap magic and the tap stuff felt alot slicker.
ford69557ci
Postby MikeThomas » Sat Apr 19, 2008 6:58 pm
SO, whats new with the camplate stuff????
1993 W250, 5SPD, ne370's, HTT STAGE IV/14wg, DennT Pin, BHAF, P-PUMP, PUMP TWEEKS, 4" EXHAUST, 366
MikeThomas
Postby cummins king » Sun Apr 20, 2008 6:58 am
Ya i got an email 400 bucks, i was so mad when he told me that and i emailed him back letting him have it and he droped the pice to 320 shipping included, but i have to buy 2, im buying one and i think i have a buyer for the other one, if any body else is intrested let me know so i can see if i can get a better deal for more
Joel
93 4X4 auto
cummins king
Postby cummins king » Mon Apr 28, 2008 4:13 pm
i got my 4mm cam plate today i will post some compar... pics later
but for now im going paintballing :D
93 4X4 auto
cummins king
Postby cummins king » Tue Apr 29, 2008 7:02 pm
left side 4mm, and right side 3.4mm
93 4X4 auto
cummins king
Postby seeker1056 » Tue Apr 29, 2008 7:16 pm
nice lookipiece - how much did you say they are now that they are made?
Sponsors of new truck
Performance Diesel Injection
Colt Cams
H&H Offroad
Arties Transmission
Toms Contracting
seeker1056
Postby cummins king » Wed Apr 30, 2008 4:30 am
they want 350.00 for them but since i bought a bunch of stuff from them and two cam plates they gave it to me for 300.00 plus 20 shipping
and after i purchased them they sent me an email saying thy didnt thing it would be a good idea to run the 4mm with the 14mm head, haha
93 4X4 auto
cummins king
Postby big specht » Wed Apr 30, 2008 6:23 am
Why I think that would all go together good more lift and a bigger head ?????
I WANT YOUR ATC'S
big specht
Postby Begle1 » Wed Apr 30, 2008 9:00 am
big specht wrote:Why I think that would all go together good more lift and a bigger head ?????
The greater lift with the bigger head is just going to beat itself apart at RPM...
Postby DTanklage » Wed Apr 30, 2008 10:07 am
prolly has to do with keeping the pressure up there?
maybe they think you CANT supply it with enough fuel?
bigger better more
thats always been my motto
DTanklage
Postby 75Dodge » Wed Apr 30, 2008 11:21 am
CK that rotor is AWESOME! but can the internal springs take that much more compression? WHat if you put in stiffer springs in the head? Has anybody tried that? I have a pump here, off-highway, that has stiffer, but smaller, springs than my pump. You think that would increase output pressure to the injectors?
1989 D-250 LE Automatic 150hp at 55mph! 3200K Spring, tweaked pump, H1C/H1E hybrid.
75Dodge
