dyno numbers
Postby DLittle » Sun Jul 26, 2009 9:55 pm
New #'s for me 393/733.
Dana
1992 W250 auto, 290 k, stock for now SOLD
1973 W100 SWB, D70,D60, 5.9 Twin Turbo SOLD
1993 W250 193k, Auto, TOTALED 10/30/2009
DLittle
Postby DLittle » Sun Jul 26, 2009 10:27 pm
Dana
DLittle
Postby KTA » Mon Jul 27, 2009 7:25 am
Wow a 7% correction factor is pretty healthy. Why is it soo lazy? What are you running for a turbo?
Postby DLittle » Mon Jul 27, 2009 6:57 pm
KTA wrote:Wow a 7% correction factor is pretty healthy. Why is it soo lazy? What are you running for a turbo?
I'm not up on the correction factor thing. What does it do ?
Turbo is a 14w/g H1C with a 60mm wheel. W/G set to 38psi.
Not sure why it's lazy. Could it be the dyno ? or the operator driving the truck ?
Dana
DLittle
1st Gen On The Dyno
Postby RSWORDS » Mon Jul 27, 2009 7:29 pm
89 Cummins
6x16's
Silver 62
Pump Mods
3200 Spring
Goerend Convertor and Built 727 Tranny
Walbro 392 lift pump
82 Jet For The Nitrous
297.48HP 532.23 Uncorrected Fuel Only
336.92HP 602.70 Corrected Fuel Only
376.63HP 675.99TQ Uncorrected w/ Nitrous
426.94HP 766.30TQ Corrected w/ Nitrous
Everyone said it looked like it made more. Even Mike the guy running the dyno was surprised of how low the numbers were.
1st Run Is Fuel Only
2nd and 3rd Were With The Nitrous
http://www.youtube.com/watch?v=M6XPr6Oy ... annel_page
RSWORDS
Postby KTA » Tue Jul 28, 2009 11:10 am
The correction factor added 7% to what your truck actually made that day in that location. Correction factors are designed for naturaly aspirated cars and are intended to make numbers from diffrent places compareable. Usually if the correction factor is more than 4% then it must be at high altitude, and that correction factor is bogus on a turbo engine because they don't lose as much power at altitude as a naturaly aspirated motor does. As for the lazy the only thing I can think of was how were they measuring rpms?
Postby RSWORDS » Tue Jul 28, 2009 12:30 pm
KTA wrote:The correction factor added 7% to what your truck actually made that day in that location. Correction factors are designed for naturaly aspirated cars and are intended to make numbers from diffrent places compareable. Usually if the correction factor is more than 4% then it must be at high altitude, and that correction factor is bogus on a turbo engine because they don't lose as much power at altitude as a naturaly aspirated motor does. As for the lazy the only thing I can think of was how were they measuring rpms?
I had a long discussion about this with John P this weekend. He wa his train of thinking. He said he used to not take CF's seriously. Then he took his drag truck to denver and lost a full second in the 1/4. Also he said that even though we have a turbo we are still putting the same volume of air into teh motor but thes is less oxygen in that same amount of volume from the altitude. He said there should still be a CF, if its as givng as the gassers that he does not know. I dont know what way to think on it.
Mike also said that n/a vs. forced induction does not effect the CF. Its all about what the avalible oxygen in teh air is (and humidity).
RSWORDS
Postby Richie O » Tue Jul 28, 2009 2:18 pm
I know this last weekend the NHRA was at sea level running and last weekend they were in Denver. All the teams kept saying alltitude does not effect the blown cars as much as the pro stockers. I know it does slow them down but the pro stockers seam to really be on the short end. I know the blown cars will run a different pulley count to speed up the blower. Maybe that is where they are making up the difference so the effect is counteracted.
Postby KTA » Tue Jul 28, 2009 5:28 pm
All things being equal the correct Correction factor for elevation on a turbo diesel is about 1% per 1,000ft of elevation. So in Denver a CF of 5% would be pretty accurate.
Postby RSWORDS » Tue Jul 28, 2009 6:30 pm
what would you add in for temp and humidity? our correction on NC on Daves dyno was 13%-15% seemed REAL high.
RSWORDS
Postby Richie O » Sat Oct 17, 2009 1:56 pm
Well the 93 went on the rollers.
6X16's, 16 cm housing, 60 GDS wheel, fuel screw 3 turns out from max, light starwheel settings, smoke screw all the way out, M+H M2 fuel pin, piston lift pump, stock timming, stock 386 spring, no ksb hotwire, stock downpipe and transfer case pipe, rag with 4.10's. Ran in direct.
The run was 301 hp and 731 torque. No idea on corrected or not. ( that is greek to me ). Its a Mustang Dyno with Powerdine control unit. ( also greek to me ).
Max power was at 2400 rpm's and max torque was at 1900 rpm's.
Postby PToombs » Sat Oct 17, 2009 6:11 pm
Rich, that's pretty good! 8) Now put a 366 in it, bump the timing and do it again. ;)
Postby Richie O » Sat Oct 17, 2009 6:27 pm
PToombs wrote:Rich, that's pretty good! 8) Now put a 366 in it, bump the timing and do it again. ;)
I have plenty of power for what I want. 8)
Postby BC847 » Thu Nov 26, 2009 9:02 am
I've been goofing around on vacation this week and managed to get a slot in the local dyno . ...
447.9hp / 822.2ft/lbs #2 only (A518 non-lockup / 12mm VE).
Four days later and turning on the W/M:
Still working on it. ;)
Postby soggy » Thu Nov 26, 2009 11:17 am
Nice numbers and very nice HP curve, still above 400 horse at 4k+. Impressive. Is there any correction factor?
92 W250 VE Powered
13.31@ 98.92
1993 D350 Tow Rig
soggy
Return to Competition
