ongoing problem
ongoing problem
Postby 93 dually » Wed Jun 06, 2007 8:12 am
Dose anyone have a a trick lining up d350 coined wheels ive had the problem since i bought my truck had cast outer wheels before. Figured because of the cast wheels not being coined was my problem but im having the same thing happen with the stock wheels.Ive replaced bearings drums studs and the wheels still dont line up right any help :x :x
93 dually
Postby CAJUN 93 » Wed Jun 06, 2007 11:03 am
my rear drums have a locating pin that indexes the wheels to the proper location. the wheels have slots in them. just line up the pin to the slot and you cant go wrong. if you dont have the pins you'll just have to take your time to make sure the innies line up with the outies
daryl
CAJUN 93
Postby KTA » Wed Jun 06, 2007 4:22 pm
I use 2 coned nuts to line them up works great. I got the nuts out of the Stud bin at my local parts house.
Postby wannadiesel » Thu Jun 07, 2007 7:23 pm
KTA wrote:I use 2 coned nuts to line them up works great. I got the nuts out of the Stud bin at my local parts house.
Yep. That is how the owner's manual says to do it. There's a pair in my ash tray.
Best dyno: 408/844
wannadiesel
diesel guru
Postby 93 dually » Thu Jun 21, 2007 8:37 am
thanks guys it worked
1993 d 350 htt turbo 5in stacks high flow intake .butchered fuel pin
93 dually
