1990 W250 Worht it?
1990 W250 Worht it?
Postby Bad93Cummins » Tue Mar 30, 2010 12:35 pm
Truck runs great, rebuilt tranny, 5 speed. Front spider gear and power steering pump need replacing. Tranny/T-case rebuilt 20,000 miles ago. Truck has 325,000. Lift 3" on 35 BFG's. Used as farm truck but was daily driven for years, but him and his cousion have 4 other diesel dodges so doesn't get used much. Motor runs great and doesn't leak. Worth $1500?
Bad93Cummins
Re: 1990 W250 Worht it?
Postby diesel freak01 » Tue Mar 30, 2010 12:36 pm
i would say very worth 1500
1993 d350 ctd drw 2wd auto
diesel freak01
Postby Bad93Cummins » Tue Mar 30, 2010 2:23 pm
Got another pic
Bad93Cummins
Postby Tacoclaw » Tue Mar 30, 2010 2:30 pm
Depending on the market down there, you could get your $$ back easy parting the engine, tranny/transfer, and axles.
But I'd run the nuts off if personally. :D
Postby Farmboy » Tue Mar 30, 2010 3:18 pm
I would also say it is very worth $1500. Up here any rust free 4x4 is worth at least 2500 weather it is a gasser or a diesel. but people just pay crazy money for things that are definatly not worth it also. ORDER UP MAN!
Farmboy
Postby Bad93Cummins » Tue Mar 30, 2010 3:24 pm
these have Dana 60 front and Dana 70 rear correct?
Bad93Cummins
Postby RumbleFish » Tue Mar 30, 2010 5:56 pm
the drive train is worth more than 1500 'round these parts. buy it.
Postby Bad93Cummins » Tue Mar 30, 2010 8:05 pm
do these trucks have D60 or D61 front-ends?
Bad93Cummins
Postby peobryant » Tue Mar 30, 2010 9:51 pm
Bad93Cummins wrote:do these trucks have D60 or D61 front-ends?
Unless I'm mistaken, the only trucks with Dana "61"'s were trucks equipped with 3.07 gears. All the other 4wd's should have a Dana 60 in the front and a D70 in the rear.
Postby ahale2772 » Thu Apr 01, 2010 6:27 am
so all early truck with 3.07's have a d61? whats the difference between that and a 60
Postby Mark Nixon » Thu Apr 01, 2010 7:06 pm
$1500?
I wouldn't have had to ask, it'd be in the back yard already!
I have sold the transfer case and 5 speed trannies as a conversion for $1500, with the trans needing rebuilt.
I could sell a couple more, if I didn't need a set-up for a very involved upcoming project.
Postby Mark Nixon » Thu Apr 01, 2010 7:12 pm
ahale2772 wrote:so all early truck with 3.07's have a d61? whats the difference between that and a 60
Housing offset is different on both the 61 and the 3.07 Dana 70s.
A Dana 70 with the 3.07s is easy to spot in a pile, there's an extra machined spot on the top right of the diff cover surface.
There's some Ford and Dodge (Van?) applications that used D-61s with 3.54, 3.73 and 4.10s, but I only started paying attention a couple years ago on the 61s.
Haven't seen too many.
