by CAJUN 93 » Wed Jul 18, 2007 8:12 am
the big drain hose is the crankcase vent tube. it will drip oil, especially if your partial to higher rpm full throttle accelleration
. if that's all thats dripping, don't worry about it.
the clutch slave will drop fluid level slowly as the clutch wears. same as the brake cylinder. fill it and keep an eye on the level for a while. if it drops, find the leak and fix it.
daryl
