help with 7000 ford
All of 'em
help with 7000 ford
Postby 1STGENFARMBOY » Tue Apr 06, 2010 11:10 am
my buddy just got his tractor back together with a new head gasket and turbo rebuild and
now it blows what looks like oil out the exaust, ant thoughts???
Darwin
Re: help with 7000 ford
Postby IowaCummins » Tue Apr 06, 2010 12:35 pm
valves adjusted improperly? could be lettin fuel out before it burns. timing messed up? idk im just thrrowing out some ideas
IowaCummins
Postby 1STGENFARMBOY » Tue Apr 06, 2010 1:23 pm
THATS WHAT NEED IS IDEAS
thanks man Dar
Postby IowaCummins » Tue Apr 06, 2010 1:32 pm
what about the new turbo, the oil seal? coulda been marred when installed and now spews oil?
IowaCummins
Postby JD730 » Tue May 04, 2010 3:48 am
1STGENFARMBOY wrote:my buddy just got his tractor back together with a new head gasket and turbo rebuild and
Darwin
Pull the turbo off and see where the oil is coming from. If the manifold is dry, then the problem is the turbo, if its not, then you need to do some more investigating.
Mike
The "Rattle Box"
JD730
Postby 1STGENFARMBOY » Tue May 04, 2010 6:40 am
It turned out to be a cracked block and a screwed up turbo so he just put a new short block
and a new turbo still don't have it together, my friends boy is doing it as a final grade in collage.
sorry i hadn't updated the project.
Return to Other diesels
