Best Getrag pulling clutch?
Postby motorwood » Sun Jul 11, 2010 9:30 pm
I'm gonna pull my 92. Whats the best pulling clutch that fits a Getrag? Not looking to spend a huge amount of money and clutch needs to look stock from the outside (class doesnt allow slipper clutches) Drivability isn't an issue since this is a playtoy.
'03 2500: utility body stock; '92 350 flatbed: maxed fuel, 354 spring, 6x.016's, 14mm H/R, 2.8plate, studs, springs, A1000 5/8 line, Super40 = 454hp 1080tq all fuel. Have added S3 66/74/.91, O-rings, home port job, Steedspeed t-4 manifold. Hp=437/857 :( 13mm P, 5x.025, he551+ht80 843hp 1thousand something trq. Broken 5th gear.
motorwood
Re: Best Getrag pulling clutch?
Postby motorwood » Mon Jul 12, 2010 6:00 am
Did some checking, Do I have this right 89-94 clutches are the same (1 1/4 X 10spline) for Getrags and 4500's and these are all "non ETH" whatever that means. So I could use my LUK that I bought for my 3rd gen if I had the correct flywheel and a starter spacer?
motorwood
Postby motorwood » Mon Sep 27, 2010 5:36 pm
I bought a 2 disk carbon ceramic with a billet flywheel from Kennys Pulling Parts. Install went well, very fun to be able to go full throttle and hold it. Gonna pull on 2 Oct, 2010 at MontAlto, PA
motorwood
Postby motorwood » Thu Nov 04, 2010 7:05 am
Have pulled the ole War Wagon 4 or 5 times this year. I pull against trucks with twice or more horespower. My goal was to not finish last and have fun. Have accomplished both! Cant wait to put the POD's and H1C/E combo to the test April 2011. It feels mighty strong!
motorwood
Postby Richie O » Thu Nov 04, 2010 12:53 pm
motorwood wrote:Have pulled the ole War Wagon 4 or 5 times this year. I pull against trucks with twice or more horespower. My goal was to not finish last and have fun. Have accomplished both! Cant wait to put the POD's and H1C/E combo to the test April 2011. It feels mighty strong!
I hate being last. :evil: Don't care if I win, but hate last.
Postby motorwood » Tue Nov 16, 2010 6:34 pm
Put the War Wagon on the dyno today, very pleased 379HP 848tq!
motorwood
Postby therabbittree » Thu Jan 27, 2011 6:41 pm
How is the Kennys clutch to drive?.. do you have to float the gears without the clutch, or do you shift like a regular single disk?.. I had an enterprise dual disk pulling clutch in my excursion etc it had to float shifted. I'm looking to get one for my truck I just pulled a good getrag froma my parts truck. I have to pull my broken getrag tommarrow..what was the price range on the kennys?
Thanks
Deo
therabbittree
Postby dazedandconfused » Fri Jan 28, 2011 6:09 pm
motorwood what hydros are you running with your DD?
http://www.kennyspullingparts.com/TRUCK ... TCHES.html
Postby motorwood » Sun Mar 13, 2011 9:28 pm
sorry guys, i havnt checked this in a while. Stock hydraulics work with no problem(4000lb plate). Shifts like a stock clutch, just a little grabby at takeoff. Highly reccomend Kenny's
motorwood
Return to Competition
