Scheid 07 dyno vid 443hp 851ftlb
Postby bgilbert » Sun Aug 26, 2007 8:51 pm
Scheid 07 dyno vid 443hp 851ftlb: http://www.youtube.com/watch?v=3A345he8yK0
More fuel, more air, and more lots of stuff than last year's setup where I made 450hp 920ftlbs... Someone got one of those Ford intercoolers they want to get rid of? :lol:
Bill Gilbert
Postby KTA » Mon Aug 27, 2007 5:59 am
I suggest a better turbo to make more power. 8)
Postby PToombs » Mon Aug 27, 2007 3:51 pm
I'd say not enough air. I guess this proves my theory that aftercoolers restrict air flow on a high horsepower unit! :wink:
Postby oldestof11 » Mon Aug 27, 2007 6:00 pm
I loved it when the wind changed direction and those guys were hurrying away from your smoke! :lol:
Postby KTA » Mon Aug 27, 2007 9:03 pm
What happened to all of your IRP smoke? When it starts getting up a bit the smoke cleans up alot more than it did?? I am thinking you have a fuel delivery issue as well as that lag pig pro52. :twisted:
Postby bgilbert » Tue Aug 28, 2007 10:03 pm
KTA wrote:What happened to all of your IRP smoke? When it starts getting up a bit the smoke cleans up alot more than it did?? I am thinking you have a fuel delivery issue as well as that lag pig pro52. :twisted:
My IRP 423hp number was with the SP66 and a little more timing. I think the Pro52 is, as shown, cleaning up the smoke a little bit more than the smaller s300. Also this run has slightly less timing, afc lever grind, pin grind, and no afc spring.
I think next will be twins, using the sp66 along with a s400. Then if that doesn't work, a cam and maybe some valve work. I need a rich ole lady! LOL
Postby PToombs » Wed Aug 29, 2007 4:03 pm
Jeez! After ya got rid of the good lookin' one? :lol:
Postby dpuckett » Thu Sep 20, 2007 4:07 pm
Hey, money will keep you happier longer than good looks. If ya get lucky, you can get both for a while.
DP
Postby PToombs » Thu Sep 20, 2007 4:13 pm
That's the voice of experience right there! :shock:
We know where you're at! :lol:
Return to Competition
