KTA wrote:1st you cut the correct outside diameter of the threads. Then you set the lead screw on the lathe to match the thread pitch. Since my lathe is big and the thread pitch is fine I then determine the proper depth of cut to cut the thread minor diameter. Then you set the minor diamter at the end of the part close the half nuts on the lathe, let it cut the length of thread you need then back the cutting tool out really fast at the end of the cut and simultaneously open the half nuts to keep the table or curtter from crashing into anything. Cutting up next to the chuck like that is always fun! Good thing is you can do this with the lathe turning slow so reaction time isn't real critical. You can also cut internal threads by this smae method, but I find a tap is easier.
JQmile wrote:Killer stuff! I'd be sending mine out if I hadn't got it tested already
Mine was 370cc at 2,500rpm and full de-fuel by 3,900rpm, although I am too scared to spin it much past 3,500.
burnt_servo wrote:is it possible to get the 6x.018's to burn cleaner than the pods ?
KTA wrote:I took some pictures of the testing, but since I lost my site that used to host pictures I don't know a good place to put them. Can anyone recommend a good free site that doesn't change over time? I don't like photobucket becuase it seems in 2 or 3 months the pictures no longer link correctly.
