My truck had been sitting for a couple weeks when I went out to start it. I hit the key and there is nothing. No click or anything. The battery is fully charged and the terminals are clean. I had wanted to go through it anyway so I replaced the plunger and contacts as well as cleaned up the connections inside there. The old contacts were about half way worn down.
The small wire post on the starter is not getting power with the key. Is there any fuseable links or relays I should be looking at? Ignition tumbler a common failure? I did some searching but everything I come up with says its the neutral safety switch on the auto. I have the Getrag , so that's out. Anyone have a good wiring diagram? Just looking for help before I start chasing wires through the steering column.
Thanks.
