Pins 11 and 12 on the PCM connector are the grounds. Looking at the connector from the wire side of the plug. Top row of wires. The first 2 wires to the left side of the hold down bolt. Both are tan wires. They meet in a juction somewhere with 3 more wires. So take a multi meter and pull the PCM plug and check these two pins to a good ground and see if you show contunity.
You replaced the crank senosr. What did you set the gap at?
