Fast ve pump trucks....
Re: Fast ve pump trucks....
Postby shiftycapone » Sun Mar 27, 2011 12:16 am
c12h26 wrote:My quickest et is 12.56@106. that was with 3.07 rear 727 trans and he351ve,over the winter i put in a rebuilt 518, 3.54 rear, and a HX52.I hope to run in the high 11s with this setup. truck only weighs 4700 with me in it
Still on stock injectors?
1990 D250
shiftycapone
Postby c12h26 » Sun Mar 27, 2011 6:06 am
shiftycapone wrote:Still on stock injectors?
yeah still running stock injectors
1991 D250 reg. cab 518
4" turbo back,pump turned up,bumped timing,intercooler,HX52,366 spring,ground AFC lever,piston lift pump,Goerend converter,M/T ET street radials,nitrous,lowered.
c12h26
Postby c12h26 » Sun Mar 27, 2011 6:21 am
heres some pics of the 52 on the truck
c12h26
Postby Cnp22 » Sun Mar 27, 2011 9:04 am
What kinda boost you seeing with that set up?
1992 auto, pump mods, 5x16's, 66/74, 8.9 1/8th
1992 getrag, p-pump, 540hp 1300fttq, 8.4 1/8th, 13.2 1/4
Cnp22
Postby c12h26 » Sun Mar 27, 2011 11:09 am
Cnp22 wrote:What kinda boost you seeing with that set up?
50 psi
c12h26
Postby shiftycapone » Sun Mar 27, 2011 12:24 pm
50 psi
How does it spool for you? Mine drove nice on my p pump truck.
Enjoying overdrive with the new 518?
1990 D250
shiftycapone
Postby c12h26 » Sun Mar 27, 2011 1:36 pm
The turbo spools very nice even with the goerend converter.yes im enjoying overdrive, with the 727 i was going through the traps at 4100 rpm
c12h26
Postby SNOOT » Sun Mar 27, 2011 2:04 pm
Sure hope you got them hose clamps good and tight... :lol:
1993 W350
SNOOT
Postby Cnp22 » Sun Mar 27, 2011 4:06 pm
That 50 psi with spray?
Cnp22
Postby c12h26 » Sun Mar 27, 2011 5:40 pm
Cnp22 wrote:That 50 psi with spray?
no ,the 52 cleans up all the fuel
c12h26
Postby shiftycapone » Sun Mar 27, 2011 8:54 pm
So have you hit the track with the new setup? I'm amazed how fast you have already gone with so few modifications. Stock injectors is just awesome.
1990 D250
shiftycapone
Postby c12h26 » Mon Mar 28, 2011 10:17 am
No i have not been to the track with this setup, still have to rebuild the trac lok and put T-bolt clamps on the silicone couplings
c12h26
Postby Cnp22 » Mon Mar 28, 2011 10:20 am
Well let us know when you do get it on the track can't wait to see what it will do!
Cnp22
Postby BC847 » Mon Mar 28, 2011 4:51 pm
I'm hoping to be quicker soon . . . . . . . soon as I get the stupid trans back together. :? There's an input and intermediate shaft in a brown truck somewhere.
I've still to mess with the IP. It's never been out of the truck. Other than the governor spring, it's OEM. There's a couple of cores in the shed ready to go into the blender.
Got a new cut-off wheel for the grinder, and a funky new torch-tip. Yee-haa! :pottytrain:
Postby Cnp22 » Mon Mar 28, 2011 6:28 pm
Iv seen some pics of your truck over on compd and you have a VERY nice truck! What are you planning on doing with the ve pump?
Cnp22
Return to Competition
