255/85 r16 BFG km2's (a couple pictures)
Re: 255/85 r16 BFG km2's (a couple pictures)
Postby IrishChamp » Sun May 22, 2011 3:28 pm
No stock height with standard saggy front. Zero rubbing.
slow_90firebird wrote:Is your truck lifted or leveled at all?
I just dont see buying 4 new 8lug wheels when I have 4 on there already that I know are rated to take the weight of the truck... I bet I could squeeze those on my wheels. I need to measure my rim width again at work one time with the thing for the tire balancer.
1993 W250, 115k miles, pump turned up, M&H Timing Spacer, built a518 w/ steel stator spec rite, he351ve, 16" steel wheels, 255/85r16 BFG Km2's
IrishChamp
Postby slow_90firebird » Sun May 22, 2011 4:18 pm
Oh ok cool. I might even be able to get that size then before I level the truck.
If your front end is as saggy as mine, i bet your bumpstops are less than an inch off the springs... which will be a saving grace to your fenders ha ha
slow_90firebird
Postby Fred_M1010 » Mon May 23, 2011 1:23 am
IrishChamp wrote:I'm drawing a blank right now, I think my wheels are 7" wide. Tirerack says they fit on 6.5 to 8 inch wide rims.....
slow_90firebird wrote:Thats the size I want to get, how much did you have to lift the front end to not rub? Also, are those wheels about the same offset as stock ones?
The reason I ask is cause I want to put them on the stock steel wheels, and im not lifted at all.
[Edit] just looked online at those unique wheels, seems like the only 16" in our lug pattern is 8" wide. I might have trouble squeezing those on stock wheels that are 5.5" wide IIRC.
If it's the 16x7 wheel, it's got 0 offset.
I think the stock steelies are about +15mm offset but I'm not sure
http://www.uniquewheel.com/scripts/seri ... Series_297
They will work on the stock wheels.
I have 287/75R16 tires on 6.5" stock steelies from a Chevy K30,
and I don't think the dodge wheels are any narrower than that.
-91.5 W250
Fred_M1010
Postby IrishChamp » Mon May 23, 2011 4:18 pm
I just checked and I have an inch max as well.
slow_90firebird wrote:Oh ok cool. I might even be able to get that size then before I level the truck.
IrishChamp
Postby IrishChamp » Mon May 23, 2011 4:26 pm
I believe my wheels are 16x7, zero offset, 4" back spacing. They have a tucked OEM look, not the flared sticking out look most like.
IrishChamp
