2nd Gen front axle
2nd Gen front axle
Postby collegekid » Tue Jun 21, 2011 6:25 pm
Tossing some ideas around, taking an nv 4500 or 5600 with drivers side drop tcase, run that to a dana 60 off a 94-98.5. The only problems I forsee are axle width and steering clearance....are those actual problems, or will they line up?
collegekid
Re: 2nd Gen front axle
Postby Philip » Tue Jun 21, 2011 6:40 pm
The 94+ year models use trailing arm suspension. Your 1st gen uses leaf springs. The 94+ axle will not have mounting provisions for the leaf springs. You would need to fab spring mounts. If the diff center section is to far to the left. The center casting might need modified to something like the 1st gen right side spring mount looks like.
I don't know of anyone that has done what your thinking of.
Postby collegekid » Tue Jun 21, 2011 6:46 pm
I was thinking of just torching the spring perches off and putting my own spring perches on, welding them up, and if the drive angle from the diff to the tcase is to steep, I can always run high angle u-joints on my front driveshaft
I wont be using the 4wd everyday, but monthly without a doubt
collegekid
Postby RumbleFish » Tue Jun 21, 2011 7:11 pm
Sounds like a d60 from a ford might be easier...
Postby collegekid » Tue Jun 21, 2011 7:19 pm
Why do you think that?
collegekid
Postby Tacoclaw » Tue Jun 21, 2011 7:33 pm
http://www.pirate4x4.com/tech/billavista/60_front/
If you got the time, you'll find EVERYTHING you'll want to know.
Besides actual installation stuff that is. 8)
Postby collegekid » Tue Jun 21, 2011 7:38 pm
All I can say is WOW!!!!!!! Thats some serious info.....Ill need a pot of coffee to get through it all
collegekid
Postby Mark Nixon » Tue Jun 21, 2011 9:23 pm
I fail to see the benefit of putting a D.S. drop in the older trucks, especially since either tranny you mentioned (NV4500 or NV5600) will bolt the the NP205 case, anyway.
Sometimes a perceived "Improvement" is more detrimental than beneficial.
This would be one of them, IMO.
Postby collegekid » Tue Jun 21, 2011 9:33 pm
Thanks mark, I think ill just stay true to the 1st gen, I was just looking for an "easier" or more logical option, but ill trust ya'lls opinion
collegekid
Postby ciamcoop » Wed Jun 22, 2011 3:11 am
Besides, the 2nd Gen axles use unit bearings. Boooo
'93 W250LE 4x4 club cab, getrag, denny t, 366 spring, 181/210 cam, bored. 020, KDP, 5x.014's, piston pump, 4" tbe, cold air, 255/85/16s, 3.54's one wheeler peeler
ciamcoop
Postby PToombs » Wed Jun 22, 2011 5:32 pm
ciamcoop wrote:Besides, the 2nd Gen axles use unit bearings. Boooo
$165 a pop and about 2 -3 years out of them. And it's usually more like squawk, snap, groan and "Awww siht!" than pop. :lol:
Postby oldestof11 » Wed Jun 22, 2011 6:25 pm
I just replaced the unit bearing in my 98 Golf. What a *itch! And the cheap $30 ones were .20 BIGGER than the hub they NEEDED to be pressed into! I spent $80 for one that fit. I couldn't imagine a truck bearing!
Postby PToombs » Thu Jun 23, 2011 6:15 pm
Yeah, it's nice to live in the salt city. 1 I had to seperate and then burn the hub out of the knuckle. Never Seize is my friend! I also drilled and tapped the new bearings on the 97 and put in greae fittings. We'll see how long they last. ;)
Postby Richie O » Thu Jun 23, 2011 6:23 pm
I had a 97 1 ton that just needed rotors. Had to torch off both hubs to do it. They would not come off in 1 piece. They were low mile factory ones too. Just plain rusted together.
Postby Mark Nixon » Thu Jun 23, 2011 6:39 pm
Richie O wrote:I had a 97 1 ton that just needed rotors. Had to torch off both hubs to do it. They would not come off in 1 piece. They were low mile factory ones too. Just plain rusted together.
Sounds like a true marriage!
"I now pronounce thee "Mr. and Mrs. Rust", you may now stain the Bride! :roll:
