bad brakes!
bad brakes!
Postby bwise636 » Tue Jul 26, 2011 7:09 am
Getting ready to rear into the brakes on my 93 dually.any suggestions on where to order parts. From what ive read could need quite a bit of new stuff. Any tips or tricks would be greatly appreciated! Not exactly my area of expertise ...
93 club cab 350 auto: steel forward planitary /custom intake/ denny t afc delete/pump tweaked/ 4" turbo back straight piped/ DNR tps delete JUST GETTIN STARTED
bwise636
Re: bad brakes!
Postby ahale2772 » Tue Jul 26, 2011 7:32 am
I've always liked the quality of stuff from napa, but many times they will give you adjuster kits/ maxi kits that will be missing some parts ( usually from people stealing stuff out of kits then Returning them) just check all parts they sell you before you leave the store, I've had it happen to me 3 times consecutively on the last three truck I did brakes on, but I like the quality of parts better.
Advance is ok but I like supporting napa better, they are usually faimily owned.
My .02 dollar
Re: bad brakes!
Postby collegekid » Tue Jul 26, 2011 7:37 am
^x2
collegekid
Re: bad brakes!
Postby ellis93 » Tue Jul 26, 2011 8:26 am
Save your skin on your hands and find some of these
They're the brake spring tools for the 3/4 or 1 ton trucks.
Re: bad brakes!
Postby ahale2772 » Tue Jul 26, 2011 9:06 am
Nahhhhh... if its your first time doing drum brakes you need to do it like all of us did.... worn out pair of vice grips with worn down teeth so when your RRRIIIGGGHHTTTTT there and almost have the spring hooked it slips off and your hands go flying twards the edge of the shoes at 900 miles per hour :lol:
...or do what wise mister Ellis said :grin:
Re: bad brakes!
Postby ahale2772 » Tue Jul 26, 2011 9:09 am
FYI, replace your wheel seals at the same time if you didnt know that allready, they dont like to be pulled off then re-installed, sometimes the inner spring will fall of and cause it to leak.
also, sometimes its easier to pull the whole backing plates off the truck and do it on the shop table, its relitivly easy and only takes 4 bolts to get them off
Re: bad brakes!
Postby bwise636 » Wed Jul 27, 2011 4:01 pm
Thanks everybody. Somthing i was also woundering is does it matter what order you bleed in and if i do a new master cylinder a guy told me to benchbleed it. Can anyone explain with alittle more detail what hes talking about?
bwise636
Re: bad brakes!
Postby dazedandconfused » Wed Jul 27, 2011 5:27 pm
When you get a new master cylinder it will come with 2 little fittings and hoses. Fill the master up and screw the fittings into the and attach the hoses running them back into the top. I use an extension in the place where the rod goes and pump it like you were pressing the pedal. You can hold it like I do or place it in a vice like most do. Bleed farthest away from the master and work your way to the front. Passenger rear, drivers rear, passenger front then drivers front. Atleast that's how I've always done them.
Re: bad brakes!
Postby bwise636 » Wed Jul 27, 2011 6:06 pm
Thanks man.Appreciate the help.
bwise636
Re: bad brakes!
Postby dazedandconfused » Wed Jul 27, 2011 6:20 pm
The master will come with directions that tell you to do what I just did. I'm limited on tools at home so my bench vice is a metal chair and my hand. :lol:
Re: bad brakes!
Postby ahale2772 » Wed Jul 27, 2011 7:03 pm
yep, as long as you get fluid out of the master before you hook it up your cool, you can do it on the truck with the lines off too, with another person being the pedal man.
ive found that these trucks dont like to give a nice brake pedal unless you bleed some serious fluid out, just did all new stainless lines in a 93 that took 2 masters worth before i got it good.
Re: bad brakes!
Postby bwise636 » Thu Jul 28, 2011 2:35 am
Did you get your stainless lines in a kit or have to buy em individually?
bwise636
Re: bad brakes!
Postby ahale2772 » Thu Jul 28, 2011 5:30 am
I make them up custom, stainless/ nickle line, stainless armor guard and stainless nuts, parts are expensive but the finished product us nice
Re: bad brakes!
Postby ellis93 » Thu Jul 28, 2011 6:24 am
Hey alex, how about throwing up a pic. I'd like to see them. Might turn into another clear pto cover thing for you ;) :lol:
Re: bad brakes!
Postby ahale2772 » Thu Jul 28, 2011 6:47 am
Okay, I'm getting the truck back to do a Denny t pin and some more tuning this weekend I'll snap some then, they came out great.
I did a 91 with one of the stainless brake kits you can buy online, the are ok but what's the point of stainless lines with alumacoated armorguard and steel nuts? Pluss I had to rebend most of the lines to fit correct.
Did that 91 with stainless/nickle fuel lines too :grin:
