VE 14mm CUMMINS POWERED OLIVER SUPER 88
Re: VE 14mm CUMMINS POWERED OLIVER SUPER 88
Postby oldestof11 » Wed Aug 24, 2011 3:49 pm
Careful! If that engine gets unloaded really quick it can go over 4k rpms... I do believe some people are able to hit 3800 with a 3200 rpm spring...[url][/url]
Postby dazedandconfused » Wed Aug 24, 2011 4:06 pm
Care to share a few specs on the engine.
Postby mauss440 » Wed Aug 24, 2011 7:37 pm
9MM wrote:What is with that intake on that cummins?
milled head
mauss440
Postby mauss440 » Wed Aug 24, 2011 7:38 pm
oldestof11 wrote:Careful! If that engine gets unloaded really quick it can go over 4k rpms... I do believe some people are able to hit 3800 with a 3200 rpm spring...[url][/url]
This one will is set up 4400-4500 rpm.
mauss440
Postby mauss440 » Wed Aug 24, 2011 7:45 pm
dazedandconfused wrote:Care to share a few specs on the engine.
.020 over flycuts 15.1 comp
pulling camshaft
.093 fuel lines
14mm main studs
head studs
fire ring head
scheids 14mm pump 4400-4500 rpm
scheids 5X18 sticks
ported and polished head-head milled-custom intake
hamiliton valvetrain-bee hive springs,keepers,locks,retainers.
66/74/90 non wastegated billet wheel
blueprinted-balanced..........and a few other goodies..
mauss440
Postby mauss440 » Wed Aug 24, 2011 7:49 pm
kenny pulling parts- 2 disc clutch
mauss440
Postby mauss440 » Wed Aug 24, 2011 8:07 pm
pulling camshaft
.093 fuel lines
14mm main studs
head studs
fire ring head
scheids 5X18 sticks
AFC deleat pump..
mauss440
Postby JQmile » Thu Feb 16, 2012 3:49 pm
This thing ever get down the sled track yet?
JQmile
Postby dazedandconfused » Thu Feb 16, 2012 4:01 pm
I believe he already sol the pump and stuff and went P-pump. The stuff was for sale on here a while back.
Return to Competition
