dazedandconfused wrote:Try rotating the tires first and make sure the back of the wheels still don't have mud caked on them. Usually it's in the tierods and such that cause the death wobbles I've seen. My 01 dually would do that and it was the tires on the front.
dazedandconfused wrote:If you have a bad tire on the front that could cause it. Do you feel it real bad in the steering wheel? The second gens are bad about trac bars and tie rod ends causing it. You can look out the window nest time it does it to see if tires are shacking left to right. I fought it in 2 dually's now. One was my 01 and the other was a 95 Ford F250 4x4. Tires were the issue with both.
dazedandconfused wrote:My guess would be the shock of the wieght shifting that fast and sudden on the front wheels allows it to start the wheels wobbling.
Tacoclaw wrote:If you've got a loose pitman arm joint, or any suspicious steering joints, you still need to fix it.
My old man got to go on a wild ride in the truck I have now when his pitman arm fell off one day. It never gave any indication it was going bad or anything, it just fell right off one day when he was making a left hand turn.
142autox wrote:Death wobble usually comes from a bump to the right tire. Replacing worn steering components usually fixes it. What happens is: RF wheel hits a bump and the energy transfers to the LF, then the the violent fight between the two of which one gets to be straight.
If you have worn steering components you can't control the fight between the front wheels and you will get uncontrollable death wobble. Adding a steering stabilizer will fix it, however its only a band aid.
If nothings worn or out of balance then its usually an alignment issue. Not enough castor can cause the "shopping wheel" effect. But usually a little negative toe will stop it.
Good luck!
