My truck went into tricycle mode today.
Postby Begle1 » Sat Nov 05, 2011 3:12 pm
Why did my lugnuts decide to all fall off at 65 miles per hour on the freeway? Are these rims incompatible with the stock hubs and lugnuts, or was I the victim of stupid wheel monkey/ sabotage/ seriously absent-minded wrenching on my behalf?
I got these aluminum rims back in May sometime; they came with crappy rubber, so I bought new rubber from a tire shop and had them swap rims for me. I've driven 1,000 miles at most since then, probably closer to 500; for the last two months it's been sitting in my driveway while I installed my new turbo. I sure don't think I ever loosened them or took off my tires during that time; I didn't even realize until I was on the side of the freeway that I needed a low-clearance socket to get to the nuts, and I don't imagine that would've surprised me if I was the one that loosened them up to begin with...
Pretty amazing how well these things handle on only three wheels, if ya'll haven't had the opportunity. :shock:
Re: My truck went into tricycle mode today.
Postby RSWORDS » Sat Nov 05, 2011 3:25 pm
Alum wheel need to re torqued after a hundred miles or so from installation.... As you have found out....
RSWORDS
Postby Begle1 » Sat Nov 05, 2011 3:37 pm
You don't say?
I've seen those funny two-piece lugnuts on aluminum wheels, never heard the re-torque thing though.
Postby Richie O » Sat Nov 05, 2011 3:59 pm
Yup, I have had 2 aluminum ones over the years fly off. Re torque is a must.
Postby Tacoclaw » Sat Nov 05, 2011 4:19 pm
I tried one of those Chevy PYO wheels on my truck while I had it down for the twins. Didn't really like the offset, so I put my old wheel back on. Got the twins going, and take it out for multiple 80+ mph runs and about 2 weeks of cruising.
One day I backed out of a parking lot, crossed a set of railroad tracks(not the only set I'd hit over this period of time) and withing 100 yards I could feel my truck vibrating like crazy. Pulled over and every lug was loose on that wheel, took about 6 turns to get them seated back up. :yuck:
Sucks that it caught your fender... :evil:
Postby ellis93 » Sat Nov 05, 2011 8:11 pm
On the 2wd,the studs shank sticks out maybe 1/8 of an inch. The factory steel wheel has a raised lug seat,that avoids contact with the stud shank, that most aluminum wheels don't have. Mine did this to me twice in one week before I looked at the back side of my aftermarket wheels and seen what was up.
Postby Hansen01 » Sat Nov 05, 2011 11:14 pm
i have also been on the side of the road tightening lugnuts with pliers on my aluminum rims :D never had it fall of yet tho, also never had the back ones come loose, just the front ones, which make sense, i check them 2ce in the same week after i put them on and then just on occasions after that
Under construction...
Hansen01
Postby chrislib » Sun Nov 06, 2011 7:55 am
When I put alloy`s on mine I re-ck`ed the torque several times, wrench clicked for the 1st 2 re-torques by #3 they were tight and stayed that way. I`d re-ck them every 100 miles or so with a torque wrench till you find they stay snug.
It`s not about how hard ya hit...it`s about how hard ya can GET hit and keep movin forward.
93 W250 CC 4x4, Auto,7x010`s, D-Zilla/16cm, 5in exh, BHAF/Smoky...don`t call it ratty, that`s patina son!
chrislib
Postby cougar » Sun Nov 06, 2011 8:49 am
I've never had that happen. What am I doing wrong?
I did have a "C" clip break on an old Chevy rear end. Interesting watching my wheel and axle pass me.
01 2500 "the work truck".
cougar
Postby ahale2772 » Sun Nov 06, 2011 10:32 am
ive been there, rust between the alum rim and hub...
sucks chasing your wheel down the highway :mad:
Postby PToombs » Sun Nov 06, 2011 4:39 pm
Aren't those aluminum rims supposed to have the nuts with the long shoulder to fit down inside the rim to help center it and have more threads on the stud? I think we were discussing this at SOP, but I can't remember who all was talking about it. Maybe Philip, Ike, Jon....?
Postby ellis93 » Sun Nov 06, 2011 5:00 pm
Mine are acorn lugs and the wheels have the acorn seats. I had one set of keystone classic wheels,on a 77 1/2ton chevy,that took the shank style nuts with washers,a good looking wheel but a terrible bolting system.
Postby CumminsPower59 » Sun Nov 06, 2011 7:07 pm
Pete, it was me, as I lost a left-front five days after buying my truck, then running aluminum wheels with short 9/16" studs, the wheels were too thick for the lug nuts to fully capture the threads...that's why I went back to steelies for now... ;)
Postby Hansen01 » Sun Nov 06, 2011 7:53 pm
CumminsPower59 wrote:Pete, it was me, as I lost a left-front five days after buying my truck, then running aluminum wheels with short 9/16" studs, the wheels were too thick for the lug nuts to fully capture the threads...that's why I went back to steelies for now... ;)
mine was both fronts came loose at the same time,lol (and no i didnt forget to tighten the fronts, drove around more than a week afor it happened lol)
Hansen01
Postby collegekid » Sun Nov 06, 2011 8:50 pm
blue loctite helps keep em on there, or put anti-seize between hub and wheel to keep it from junking up
collegekid
