tack welding upper ball joints, how safe
Postby Dead Bunny » Mon Nov 07, 2011 2:04 pm
I got a set of used upper control arms. I had a shop take out the old ball joints and screw in the new ones. when they did it, they stripped out the screw holes. They told me that I can tack weld the new ball joint in and it will be fine. How much truth is in this statement. I am broke as hell and can't afford brand new moog parts.
91 cummins d250 LE
Dead Bunny
Re: tack welding upper ball joints, how safe
Postby skilletky » Mon Nov 07, 2011 2:09 pm
My dumb ass pressed the top ones out and back in and one came out on me, i welded them in last week and have not had a problem yet.
skilletky
Postby PToombs » Mon Nov 07, 2011 5:59 pm
I have one that's been welded for years. I also pressed them out and back in, not realizing they were threaded. I jacked the truck up a few months later, and the joint fell out of the A arm. I wasn't real happy. I just put it back, and tack welded it in. IIRC, when the truck is on the ground the weight holds it in. It's been awhile since I looked at it, so I could be wrong.
Postby Dead Bunny » Mon Nov 07, 2011 6:03 pm
thanks alot. BTW Pete, that inner cooler is still working great!
91 cummins d250 LE
Dead Bunny
Postby PToombs » Mon Nov 07, 2011 6:09 pm
Good deal! You should have seen the load I hauled out to there this year. No room for the cooler on that trip! :lol:
Postby hydroshok » Sun Sep 16, 2012 7:30 pm
I don't think the weight of the truck would hold it in as the spring is between the control arms on our trucks. I have tack welded my fair share of ball joins in and never had any problems. As long as you get it in all the way and straight; it should last a long time. Make sure to grease it a ton after it cools because you just super-heated the grease when you welded it. I guess if you have the time weld it with the spindle off, flush all the old grease out pump new grease in and then put the spindle on.
hydroshok
Postby ellis93 » Sun Sep 16, 2012 11:38 pm
After a year has passed I surely hope he's greased his ball joints :lol:
Postby hydroshok » Mon Sep 17, 2012 10:14 am
Ya me too... I realized that after I posted, but sometimes old threads getting new posts helps someone who is looking for info on that topic....
hydroshok
Postby PToombs » Mon Sep 17, 2012 5:08 pm
Actually, there was another recent thread on this subject. ;)
Postby hydroshok » Mon Sep 17, 2012 8:43 pm
See if I had posted earlier; that thread might not have started. I'm used to other forums where you can search for stuff instead of looking around.
hydroshok
Postby PToombs » Tue Sep 18, 2012 4:42 pm
Well, you can try to search here, but it's usually a frustrating process. Some of the guys have it down cold, and will post a link to what you are looking for. Unless you are in a big hurry then they don't get on for days. :lol:
Postby Diesel Dawg » Wed Sep 19, 2012 12:14 am
Ive had mine welded in about 2 yrs and no problem. :bom: :bom: :bom:
Diesel Dawg
Postby PToombs » Wed Sep 19, 2012 5:27 pm
It's been 3 times that for mine. :mrgreen:
Postby hydroshok » Fri Nov 09, 2012 11:21 pm
I told my roommate I welded it in place and he said "Then you can''t adjust your alignment. That was stupid!" I responded "Well that sucks. Guess I'll have to get a new truck!" He has worked at Advance auto parts the last 10 years. He also told me there is a gear lock in my manual transmission that will go bad and cause the truck to roll backwards on a hill. I'm really screwed here or he basically wasted 10 years learning about vehicles...
89 D350 5spd 83 crew cab: waiting on new drivetrain
1999 2500 5spd: 2001 HO motor, smarty, edge comp, 40hp injectors, AFE intake, AirDog, rebuilt NV4500, HX40, full air ride
hydroshok
Postby PToombs » Sat Nov 10, 2012 6:36 pm
You should have grabbed him by the ear, dragged him out there, and stuffed his nose behind the tire and said, "ya think so?". :lol:
