Dual feed VE
Postby ford69557ci » Tue Oct 30, 2007 9:56 am
:wrench: i am the best at breakin stuff
ford69557ci
Postby cummins king » Mon Nov 12, 2007 10:24 pm
i know nobodys reading this any more but
if ur running dual feed how many psi do u want the electric pump to push into the pump(were the shot of used to be)
93 4X4 auto
cummins king
Postby KTA » Tue Nov 13, 2007 8:40 am
100 would be nice if you could get it. Mine tops out at about 70psi.
Postby cummins king » Tue Nov 13, 2007 10:57 am
what ur electric pump only does 70 psi
thanks
93 4X4 auto
cummins king
Postby ford69557ci » Tue Nov 13, 2007 11:49 am
most electric pumps will max around 80psi but if yeah dead head them they will make around 150 160. i have seen several belt driven pumps that will go 175
ford69557ci
Postby GPSMatt » Tue Nov 13, 2007 12:34 pm
what if you run a EFI pump those pu tout a lot more PSI
86 F350 idi
85 F350 crew cab 4x 5.9
95 Lightning
85 GT
GPSMatt
Postby SChandler » Tue Nov 13, 2007 1:48 pm
The Aeromotive A1000 is a high end EFI pump and it tops out at 90psi (per Summit's website). It is my understanding that EFI systems typically use fuel pressure in the 40's from the fuel pump.
SChandler
Postby DTanklage » Tue Nov 13, 2007 2:34 pm
any pumps pressure depends on demand as well...
dead head numbers dont mean Dick
DTanklage
Postby ford69557ci » Tue Nov 13, 2007 5:49 pm
barry grant says that thier king sumo efi pump is what i would need for my dual feed it can spposedly pump 110psi at like 40gph i think is what he said
ford69557ci
Postby cummins king » Wed Nov 14, 2007 4:27 pm
kta u have a regulator in ur set up right, that set up to do 1 to 1 ratio to boost, so what pressure dose it start at, if the regulator is 30 to 75 psi does it mean it starts at 30 and for ever pound of boost it rases a pound of fuel till it hits 75 psi, did i make any sence
93 4X4 auto
cummins king
Postby meby » Wed Nov 14, 2007 5:13 pm
I found some electric pumps made by bosch in a web store that said they were good up to around 170 or 180 psi. If they will actually do this I have no idea. those were the only ones I could find at the moment.
-1991 D-250 bone stock
-1997 Civic Hatchback
-Case 530 CK
-Speedex Walking Tractor.
-BCS Walking Tractor
www.ebyfarmsllc.com
meby
Postby ford69557ci » Wed Nov 14, 2007 5:24 pm
whats the link i want one 8)
ford69557ci
Postby DTanklage » Wed Nov 14, 2007 5:43 pm
whatcha need to do is figure out how much fuel your pump will actually push at 3000 rpm
you know what i mean?
per minute, at 3 grand - everything, including what is returned to the tank
then you can figure out what 'a' pump will do with that demand
DTanklage
Postby KTA » Thu Nov 15, 2007 9:47 am
I run 12psi at idle plus not quite 1-1 additional refrenced to the boost. I have a boost elbow on my refrence line so its not quite 1-1.
Postby DTanklage » Thu Nov 15, 2007 1:52 pm
we are trying to put higher pressure into the case than the rotary vane pump produces brian
not just make sure there is lift pump pressure there at all times
i think the vane pump over rides your a-1000 almost instantly (if not at all times)
iow - i dont think your truck knows the A-1000 is there
DTanklage
