CONGRATS SWANK!
Re: CONGRATS SWANK!
Postby swank » Fri Nov 25, 2011 8:09 pm
first build was 13.7. The block we had donated had a broken cam in it when we got it. It was mag'd and everything, but just suffered. Lots of factors played a roll? Solid mount with maybe not enough support for the frame? Everything we can think of has been addressed at this point, unfortunately, that is everything we can think of, right? It's the stuff you don't think of that is the problem.
truck
swank
Re: CONGRATS SWANK!
Postby swank » Fri Nov 25, 2011 8:11 pm
btw, anybody should be able to view the Greenspeed Facefu** page without being a member.
All of the albums can be seen here:
https://www.facebook.com/media/albums/? ... 2186860802
truck
swank
Re: CONGRATS SWANK!
Postby KTA » Fri Nov 25, 2011 8:16 pm
Yeah these blocks are non structural and I have seen issues before with main bearing failures when the engines were mounted solid in the frames via the stock mounting locations. In reality those side mounts are really weak and in a bad place anyways. The best mounting method is a single point in the middle in the front and two mounts off each side of the bellhousing. That puts the stresses in line and blanced. The block can essentialy have freedom without being loaded by the vehicle.
Re: CONGRATS SWANK!
Postby swank » Fri Nov 25, 2011 10:14 pm
Patrick added supports at the bell housing before we went to El Mirage, next step is designing and building a new front end. I will relay this info, thank you Brian!
truck
swank
Re: CONGRATS SWANK!
Postby PToombs » Sat Nov 26, 2011 6:42 pm
Most of the industrial stuff I have seen is mounted like Brian says, center front and bell housing. ;)
Re: CONGRATS SWANK!
Postby ahale2772 » Mon Nov 28, 2011 5:24 am
Ive got one of those center front mounts from a buss if you need it. its a beefy piece for sure.
looks like an awesome build 8)
Re: CONGRATS SWANK!
Postby swank » Mon Nov 28, 2011 3:59 pm
ahale2772 wrote:Ive got one of those center front mounts from a buss if you need it. its a beefy piece for sure.
Do you have a picture? That would be good enough. Patrick and I are going to be designing a tube frame front clip next semester. We will just incorporate the mount points in.
truck
swank
Re: CONGRATS SWANK!
Postby Tacoclaw » Thu Jan 26, 2012 9:57 pm
I hope you PM'd him that pic, Alex. :P
Shamelessly lifted from DTR:
http://jalopnik.com/5860828/how-college ... ed-vehicle
Congrats again on the recognition, Swank!
Re: CONGRATS SWANK!
Postby ahale2772 » Fri Jan 27, 2012 8:05 am
nope i totally forgot...
here it is.. sorry for the wait :roll:
if you look where the tie strap is hooked, thats where the bus at545 bellhousing has provisions for the mount, never seen a buss that dosnt have side mounts like that
Re: CONGRATS SWANK!
Postby swank » Wed May 16, 2012 4:50 pm
You have a part number for that piece by any chance? Thanks!
truck
swank
Re: CONGRATS SWANK!
Postby oldestof11 » Fri Aug 17, 2012 4:15 pm
Congrats again Swank! 203mph unofficially before popping the HG.
Re: CONGRATS SWANK!
Postby swank » Mon Aug 20, 2012 7:38 am
Sure wish it was a head gasket. Pulled the freeze plugs last night, could see a piston....almost threw up. :(
truck
swank
Re: CONGRATS SWANK!
Postby PToombs » Mon Aug 20, 2012 5:03 pm
Wow, I think I'd throw up if I saw that too. Low budget just went out the window. :(
Post some pics when you get a chance.
Re: CONGRATS SWANK!
Postby ellis93 » Mon Aug 20, 2012 6:19 pm
Block filler in your future?
Re: CONGRATS SWANK!
Postby dazedandconfused » Mon Aug 20, 2012 6:29 pm
That sucks
Return to Competition
