oldestof11 wrote:On the knuckle for the steering, buy this:
http://www.speedwaymotors.com/Safety-Ra ... ,6632.html
Then cut above the pin and spread the metal until it comes out. Then do this:
The screw on the splined end is a set screw, the opposite side you can either weld or drill through. Took me 3 hours to get the pin out, 1 hour to disassemble and reassemble the steering shaft. Best thing you can do to tighten up your steering.
Full write-up here:
http://www.dieseltruckresource.com/dev/ ... p?t=93363-
GeneralC wrote:oldestof11 wrote:On the knuckle for the steering, buy this:
Full write-up here:
That looks like a really good solution but I'm not much of a welder. I'm gonna try to rebuild this shaft but if it doesnt work out ill just buy a borgeson. As bad as I hate to...
