Clocking a Np205
Clocking a Np205
Postby JustinRhodes » Thu Mar 15, 2012 4:55 pm
Is it possible? I need to have the np205 that came in my truck clocked for driver side drop.
JustinRhodes
Re: Clocking a Np205
Postby ahale2772 » Thu Mar 15, 2012 5:51 pm
EHH....
shift rails will leak, way easier and lighter to use a 241/271
Postby JustinRhodes » Thu Mar 15, 2012 5:56 pm
ahale2772 wrote:EHH....
How do you get a 241 to bolt up to a getrag :shock:
How bad would they leak?
JustinRhodes
Postby ahale2772 » Thu Mar 15, 2012 6:14 pm
same 6 bolt mounting pattern as a np205...
Postby JustinRhodes » Thu Mar 15, 2012 6:15 pm
ahale2772 wrote:same 6 bolt mounting pattern as a np205...
I know bolt mounting pattern is the same, but will a 241 slide onto the input of a getrag?
JustinRhodes
Postby JustinRhodes » Thu Mar 15, 2012 6:18 pm
Better question, how do you convert a 23spline 241 to a 29spline?
JustinRhodes
Postby Mark Nixon » Thu Mar 15, 2012 8:17 pm
The 241 is available in 23 OR 29 spline, same as the NP205s for the Getrag.
Converting an NP241 ro 29 spline is as simple as splitting the case and getting appropriate input and bearing, unlike a 205, which requires the specific case and bearing retainer to run the 29 spline input, OR a boatload of machine work.
Another POSSIBLE option is running a FORD 205 with the Dodge 29 spline input, but that may require some machine work, as well.
Postby CUMMINSDODGEMAN3 » Fri Mar 16, 2012 5:37 am
or use one of these or build one like I did...http://shop.shsdiesel.com/23-spline-to- ... OUPLER.htm
CUMMINSDODGEMAN3
Postby CUMMINSDODGEMAN3 » Fri Mar 16, 2012 5:39 am
or if you gotta buy a 241 anyways just look for a 241 thats out of a manual trans truck and it will be 29 spline or have a manual input shaft 29 spline put into case. we do it here at work all the time for people, i work at man-trans of florida.... rear outputs on automatics are 23 and manuals are 29
CUMMINSDODGEMAN3
Postby Dieselwrencher » Fri Mar 16, 2012 3:40 pm
Make sure if you do get a 241, that it has the speedometer sensor hole and sensor in it. Some of the later ones do not have them.
2000 Excursion VE 24v 47RH 4x4
1976 Chevy K30 Crew Cab Short box P-pump 12v 47RH
1972 Chavy K30 P-pump 24v 47RH
1968 Corvette 5.9 47RH
Dieselwrencher
Postby JustinRhodes » Sat Mar 17, 2012 6:49 am
Mark Nixon wrote:The 241 is available in 23 OR 29 spline, same as the NP205s for the Getrag.
Ive found the 29 spline input shaft, but how do you know which bearing is needed? Ive heard there is a narrow and a wide bearing.
JustinRhodes
Postby Mark Nixon » Sat Mar 17, 2012 7:10 am
I'm not sure WHICH bearing the 29 spline uses.
All I do know is that one of them can be a PITA to get and spendy.
Postby JustinRhodes » Sat Mar 17, 2012 7:14 am
Mark Nixon wrote:I'm not sure WHICH bearing the 29 spline uses.
Thanks for the warning :)
JustinRhodes
